i think anything that is top-feed will work. assuming they are larger than the factory size. im not sure that size is quoted in the manual, but its at home if youd like me to check?
try something from a RB26, but to be honest i have no idea what sort of flow capacity they are rated at.
maybe even VQ35DE upgraded injectors will be enough
Im looking at 600cc at least I recon, to allow further mods and E85 without getting near over-driving. I want to avoid running high pressure too. Is there one brand that stands out, especially with ethanol?
SR20? they are side feed, im 99% sure we have top feed.
except FWD SR20s, i think they are top feed.
nismo make 550cc and 700cc injectors. they may have a part that fits!
hmm... May have to change what I said. Dyslexia must have kicked in when putting the part# in Parts Master.
VQ25det injector part #16600-AA500
You are correct iain... no SR20.
Used in the following;
M35 - VQ25det (obviously)
R34 - RB25det
Y61 - TB48de
F50 - VQ30det
Apologies guys.
  • 11 months later...
I need to upgrade my injectors as they are running flat out. Any idea which injectors I need to look at that fit? I bought a tomei pump today, just need bigger squirters.
http://cgi.ebay.com/ebaymotors/350z-G35-GT...sQ5fAccessories
these actually plug and play? or will i need a spacer?
HELP
mine are at 94% lol :(
There are also
http://cgi.ebay.com/ebaymotors/DROP-IN-550...sQ5fAccessories
which are no name but guaranteed to just drop in.
ideas please
You are only maxing the flow due to running rich, my advice is to get an Emanage install to lean out the mixture and see how you go. The stock injectors should be good to around 200awkw and I dont think you are there yet.
If you decide you need new injectors, a Walbro or preferably a Nismo/Tomei pump is required also. I would suggest 550cc minimum as stock is 370cc, the second set are drop in with no plug changes.
so you reckon the second set is better?
is Walbro plug n play or will i need a spacer.
yeh i will do the emanage eventually. jus wanna do everything first like you said instead of back n forth ending up with $2000+ in tunes.
then BANG
You cant install the injectors until you have the Emanage in or it will foul the plugs just starting it.
Second set will fit, I have no idea on the quality.
where did my black hole statement go lol.
theres a couple of 350z nismo pumps on ebayfor about $100 does this seem right?
plus $500.00 for plugs
plus $1500 for emanage install tune.
someone kill me.
Emanage first, you only have to upgrade the pump/injectors if the AFR's are leaning, the tuner will advise that.
Emanage : $650 second hand
Install/Tune: $650
hmm with the loom? or do i need to make one any way..
You will need the universal loom, mine came with one, didnt it Cam. :)
lol yeh i meant injectors lol. having a blonde moment. execpt im a Curry :(
yeh theres a emanage n loom for total $550 shipped to melb.. i reckon drive carefully for a little while n check what the prices are like in december. hopefully we still have the same exchange rate lol
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
