Just now, FedBpy2018 said:
So you'd take a drag car built to go in a straight line out to drift it or track race it? If so then your crazy
I took my circuit built R33 to a skid pan, and I quickly realised I needed a smaller turbo so I bought a new smaller turbo lol
2 minutes ago, BakemonoRicer said:
Sydney roads are absolutely horrible for driving.
However Newcastle on the other hand is awesome for driving...plenty of epic roads for a blast.
R33 GTRs still rock, though, right? lol
  • Like 1
2 minutes ago, Dose Pipe Sutututu said:
and doesn't make DSG farts lol
Now here's something I can get on board HATING!! it seems every wanker in Sydney has their DSG farts modified to be louder? (not really sure nor care how that works)
Watch out for Kangaroos! I've hit 3 driving Hunter Valley roads, but yes they are very nice for driving.
  • Like 1
9 minutes ago, Dose Pipe Sutututu said:
doesn't have launch control though, and doesn't make DSG farts lol
This one had a built turbo. Any other questions?
Edited by Robocop2310
what a useless video.. no engine shot, no tech details...all turbos are built one way or another lol... please elaborate... but seriously... post this in the TRD Camry thread, as a testament to TRD being more than just a trim level. mind you as "concept" it's really not even worth discussing until it's actually produced.
Ha ha ha...I was joking...TRD or or not...my wife drives this to pick up our kids...it's like a good looking boat.
I work for toyota :)
Yes, they delete their resonators and retard heaps of timing on gear shifts to increase the farts... however they are there for a reason, to cut torque between gear shifts so the box doesn't go bang. The farts are a byproduct of timing retard between gear changes
33 minutes ago, BakemonoRicer said:
I think most people are spooked by GT-R's because the natural reaction is to lift-off when the tail kicks.
Keep that throttle on lads, and enjoy HICAS :)
Yeah you can work with it, sort of. If it starts malfunctioning, good luck. Functioning HICAS is fine for the road, but on the track it's annoying.
Anyone claiming that HICAS only improves their car control on a (let's assume fast country or hills) drive is not driving hard enough to understand the point.  Those (above) who have backed me up and described how HICAS is frightening when you are really, really up it can do so because they have experienced it.
Bakemono.....when you say "and enjoy HICAS", you really mean "enjoy ATESSA".  Using the GTR's RWD biased AWD  to conquer oversteer is not the same as having HICAS wiggle the rear wheels around because it's got no idea what it is doing.
Skylines (GT-R, GTS-5t, GTS-4) that have ended their lives in trees or poles or armcos or walls generally have HICAS.
The system is too slow to react and instead of aiding, it actually degrades handling.
  • Like 1
3 minutes ago, GTofuS-T said:
I've had the delete kit for ages, just too lazy to get under and do it.
lazy bastard lol.. the lock bar is a piece of piss.. the full eliminiator kit takes a bit of time, but worth it..  I wrote a guide too
here it is for anyone interesting in deleting the bullshit Nissan put in:
http://www.trak-life.com/diy-hicas-delete-hicas-eliminator-kit/
On 11/27/2018 at 1:37 PM, GTofuS-T said:
Well the rise in R32 price was arguably due to the US demand, so it would be fairly safe to say if they're interested in them, the same rise will occur, unless, and I've heard some people doing this with R34's too, they're buying them already and storing them until they can be legally imported, smoothing the demand rather than a big influx.
here you go... 19,000 USD for an R33 GTS-T...
Image may contain: car and text
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
