Had a strange noise start to show itself.. at idle I get a pronounced whirring noise which sounds like it's coming from the top of my engine. Seems loudest above the cam covers and only does it at idle, at higher RPM it goes quiet. Also only happens when the engine is up to temp, I think. Will have to check next cold start.
It definitely seems to be loudest above the engine, rather than at the front.. so I wouldn't think it would be any of the external belts (alternator etc). The engine's done 118k and the timing belt was done at 100k by the prev owner.
Any ideas? I'll try and grab some hose and do a bit of listening to see where it's coming from but I should probably take it to someone to find out what's going on. Suggestions would be helpful :D
https://www.sau.com.au/forums/topic/29584-whirring-noise-at-idle/
It's not the clutch, it's not the injectors it's coming from the front of the motor.
Took it to a mech who agreed and said it could be the cam belt, could be the idler bearing. Also had someone else suggest water pump. But it is a belt/bearing noise IMO. Either way it doesn't look like it's possible to diagnose without pulling everything apart, and that won't happen before christmas...
Winds down? Mine will spin for a few second after the engine has stopped, that's normal unless the clutch is engaged in which case it should stop instantly.
It's not coming from the fan belt or clutch fan region, sounds like the front of the block, and if you listen closely it sounds like the noise is coming out from underneath the timing belt cover.
Mine does exactly what Damo's does and most other's do, just the gearbox turning over/clutch.... hope thats all it is.
-rb25
It's usually the thrust bearing (the bit that actually presses on the fingers of the pressure plate). In my experience it's not a critical, must-fix, sound.
Try the old screwdriver stethiscope trick(tip against part & handle to ear). You may find that it is just the aircon belt idler pulley. This is quite common and can sound like it is coming from somewhere else. Once you have listened through a screwdriver you should be able to pinpoint the noise easily.
cheers, i will try it.. hopefully it's coming from somewhere trivially nonimportant like the air con pulleys.. which isn't even gassed so I should probably just remove the belt if that's what it is lol.
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
