Hey guys my name is Michael and i bought a 1996 R33 GTS-T yesterday and love the car. My only problem is i need new rear shocks for rego and the cheapest i have found are $700 a pair but i have already blown my budget on the car. So can anyone reccomend where i can get some fairly quick and cheaper then that?
My other question was what oil should i be using the engine is stock at the moment and where can i find air,fuel and oil filters for the car? I went down to Super Cheap but the car is not listed for these parts anywhere.
Any help or advise would be appreciated cheers Michael
https://www.sau.com.au/forums/topic/295842-newbie-needs-help/
Hey mate another Michael ,
If you need a service done let me know and I can do one for you ...
I charge $90 per hour + parts
oil filter part number off the top of my head is Z145A
And I am pretty sure that I can get rear shocks cheaper than $700 for a pair
what brand were you quoted 700 for ?
Welcome mate,
Nearly everyone will recommend Motul 4100 Turbolight oil for your motor and it can be found at Repco and Autobahn. Most places wont have a parts list for our cars, but if you can find the part numbers then they'll most likely have them or be able to get them in for you. try using the SEARCH TOPIC in various threads if your looking for this information as it had been talked about so many millions of times that it should be easy to find. servicing your skyline is so simple that a baby could do it blind folded! if you need some help just ask and most of the guys on here will be happy to help guide you through it. as for the shocks, $700 a pair is a little steep. there are only 2 places in canberra to go to for suspension and that is Inline in Qbn or Capital Steering and Suspension in Fysh. i think i got quoted about $600 a pair for Bilstein's about 4 or 5 years ago....
hope this helps...
Welcome to the forum Michael
Thats way to expensive for shocks lol you should be paying a round 500 ish give or take alittle..
As for serviceing yeah do it yourself and learn about the car just dont do what i did and thats when you flush the rad (if you do flush the rad) dont for what ever reason undo the nut on right hand siode of rad to drain just take the hose out!!
Otherwise you will be like me needing a new rad as they dont like to go back into the plastic once took out!!
Oil use Motul 4100 :)
i never had that problem and mine came out and went in a few times.
Yeah either Motul 4100 or 8100
v300
Edited by TiTAN
Mine wouldnt go back in :)
Got a 2nd hand rad that went in a few times but was leaking then it decided to not go back in after a few trys :D
Ended up going aftermarket alloy rad :)
Edited by GODZ1LLA
If you don't necessarily want brand new, I have a full set of used stock springs and shocks off a 96 R33 S2 that should get you through rego.
Since you're new here, and had good enough taste to buy a Skyline, you can have them cheap :) .
Oh, and you'll find the filters listed in the Ryco catalogue, but the imports are normally in a different section to the domestic models.
Or try www.rycofilters.com.au.
From memory - oil is Z145A, air is A360.
Fuel filter could be one of about three different models, best to take the old one in with you and just compare it.
Edited by JD_R33
theres you problem... ooooooooooooooo!!!!!!!!!!! oh no he didnt
Thanks for the help and advise guys, i just freaked out a bit when i couldnt seem to source any parts. As for the servicing i should be able to do basic stuff myself iv always serviced my own cars but thanks anyway.
Hope to meet up with you guys in the coming months if i get a chance but iv just started a new job and have to work a lot of weekends
Cheers
Edited by micksrb25
Hey mate definetely interested in those shocks it would help me out o lot. Are they off a GTS-T or a GTR because i thought there was a difference??
Also i cant PM yet so if you PM me your number i will give you a call and come and pick them up how much yo want for them??
i got stock rear R34 25GT if its the same one as yours. i need someone to clarify this.
u can just borrow it from me and return it after u pass ur rego.
nb: im not a mechanic, but i changed my springs with coilover by myself. sooo, pretty much i can help you with the main idea.
cheers
Well i put the new shocks in (thanks JD R33) and got new rear tyres, had rego check this morning and failed on front tyres which i thought were fine but inside edge was stuffed (just), after market peddles now i gotta try and find some original rubber things for the originals and it appears someone did a dodgy fix up job on one of the pipes on the exhaust so will prob need a new bit of pipe there. Damn car is costing more money then expected at a bad time of year. Anyone know where i could get the rubber things for the peddles cheers
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
