Hey Guys
Buying my first R33
Have owned and drifted a couple of S13's
Just a few questions. firstly the compression results of the motor im looking at getting in the R33 returned results of 140psi even
coming from drifting CA18DET's and SR20's this result seemed low to me but the owner reassured me this is a brilliant result for a rb25 and the compression is lower in a six cylinder, can anyone confirm this?
Steve
https://www.sau.com.au/forums/topic/295856-buying-r33-compression-results/
The compression is fine as long as its 140psi consistently. For example 140,140,70,140,140,140 would be bad.
I recently bought a 33 too, and mine were all between 140 and 145. Apparently this was good.
Edited by beamstas
Hey Guys
Buying my first R33
Hi,
No (the compression is not automatically lower in a 6-cylinder).
However, I believe 140psi on a standard compression test is a little on the low side.
The RB26 service manual lists:
171psi standard (this is what it should be)
128psi lowest acceptable value (fix if below this)
14psi maximum variance across all cylinders (fix if more than this).
When I last tested mine they were 165psi +-1 psi across all cylinders.
If you can dig up the relevant manual for your car you will know what the result _should_ be; I suspect it will be similar to the above.
Hope this helps.
Regards,
Saliya
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
