Big congrats goes to paul ( Superjet - GTR-32X ) Ran 9.9 at eastern creek tonight in full street trim ( car with full interior not a bolt removed , this car is his everyday run around mind you ) on his first ever outing in his r32 gtr , i watched as he lost traction half way through backed off then punched it again . this is a remarkable effort for paul as it is his first time at the track with this amaging car ,
congrats again good luck cant wait for the next run .
https://www.sau.com.au/forums/topic/295881-nsw-latest-rh9-member/
This car was amazing down the track......
As I watched it...
Launched hard off the make and at the 60foot mark started to wheelspin and break traction....
So backed of completely and then he hit it again...
Amazing time with alot alot more potential....
It ran a 9.959@147mph...
The car actually seemed to have to trouble in running this time and it backed off and then went again would have at least lost 0.5-1 sec...
This car has not been stripped and ran in FULL i repeat FULL STREET TRIM!!!!!!!
I honestly feel that we now have a contender for Kier Wilsons quickest GTR on Street Rubber but the funny thing is that this car in a GENUINE STRRET DRIVEN CAR!!!!!!!
Absolutly amazing effort............
Well done to Paul and everyone that helped build this car...
Ps- Moey when u taking ur car down the track.. Cant wait to see what numbers ur machine produces...
Sam ,
good to see you at the track , what a machine ay .
my car almost done couple little more touch up's should be good for a high 10 , weres your nugget at lol.... see you on the weekend bring paul down with ya .
As I watched it...
Edited by MRGTR911
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
