have no time for my r33, wanting to sell it with ni rego and slight rear quarter damage, in the pic its when it was hit but i have straightend it out so it can be easily repaired and its not that bad. i have run a 13.4 at the creek with the 19s on it n no traction, car made 213rwkw on 14psi on safe tune. so it has so much potential.
contact: pm or 0430064462
price: 8.5k negotiable
mods:
- T04e turbo
- tial 32mm waste gate
- screamer pipe
- stainless steel highmount manifold
- 3in dumpipe and full exhaust
- sard fuel pressure regulator
- sard 550cc injectors
- walbro 550hp fuel pump
- front mount intercooler
- EMS stinger 4424 computer
- turbosmart boostcontroller
- apexi turbo timer
- NEX coilovers
- custom oil catch can
- custom air box
- heavy duty clutch
- house of colour passion purple paint job
- 19in gold konig unkowns, 8.5 front 9.5 rears
- front bar, side skirts, rear bar
car runs awesome and goes hard its well looked after n always serviced, make me a offer its worth looking at to buy.
https://www.sau.com.au/forums/topic/295891-r33-gtst-s1-1994-lots-of-mods/
    • Maybe but doubt it, when I jacked it up it was creaking in the j arm again. The inners are all good, I inspected them. Remember that also it did fix the problem but temporarily.
    • Could be the other bushes. The inners.
    • Once you lose the adjustable bushes, you have almost no adjustment at the front for anything that matters. You can only wind so master caster at the front, and ~7° is fine. You won't have choice of front camber. If you only have rear camber arms (ie, do not also have adjustable upper tension arms), you shouldn't change their length very much, because you will introduce bump steer. And, you will struggle to find a workshop that will be capable of doing all the adjustment work necessary to simultaneously achieve a decent rear camber number, get the toe right, and minimise bump steer. I would guess there's probably 8 hours of work there. So, stockish rear camber is fine. Although, keep in mind, that stock camber, by number value, does not mean stock arm length when the car is lowered. You will need to lengthen the RUCA to get back to stockish values and that will require the tension arm to be lengthened a little also. Without any other guidance, any change made to the RUCA should have the 2/3 of the same change made on the tension arm. But that is only a rough rule of thumb and the relationship might not remain linear across a wide range of adjustments. And it might not also be as close to minimum bump steer as you could achieve if you did the bump steer measurement and adjustment properly.
    • Well it does have a motor with the same DNA as an Accord V6 motor. The J30A is a successor to the Tiger rice cooker C32A motor found in those cars.
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
