Well compak attak was a dissapointment for us today but hey the car is still running ha ha
First pass the left stub axle on the diff broke just as the car left the line. so we were chasing another diff for hours and with the help of hermen from envy we managed to get one off sss automotive
Put thr diff in and had to go into the first round of racing without having a qualifiying pass. we tamed the car off the start to make it 60 foot better but it didnt ike it and bogged it went 9.0 @ 156.8
and we put it on the trailer.
We hope to be back out in a couple of weeks for some more testing
Thanx Paul
  • Replies 135
  • 4 weeks later...
yeahhhhhhhhhhh bro.
that is 1 of the best gtr launches I've seen with both front wheels off the ground!
Is that con in the foregorund from c&v? I haven't seen him in over 10yrs
Those rh9 plates need to be upgraded to rh8 :blush: lol
Yea Marko thats Con they came out to the track yesterday and it wasnt a bad day the car was all over the place and went 8.93 159 again.
Its now time to spend some money on some suspension!
And plates are on the way Ha ha ha
you may be able to buy mine in a few weeks as per phone call the other day.
I honestly didn't even know there was an rh8 class, mustn't be as well known as rh9. Then again, how many 8sec gtr's are there on this planet (let alone 9sec gtr's)
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
