I'm Facing A Dilmemma Now That I'm A Member.
Do I Put The SAU Stickers On My Car Or Not.
I Usaully Hate Stickers On Cars.
But I'll Like To Show That I Am A Member.
Need Input Guys.
Do These Stickers Come Off Easily?
Not Every Word Needs To Start With An Uppercase Letter!
Stick them on a window, they come off easily with a razor blade.
Has anyone noticed if they get less attention from the boys in blue if you have the SAU stickers on?
I would have thought it was the other way around :)
Hard Kandy and PHD stickers used to be a boon for cops pulling over cars on a weekend morning :D
I would have thought it was the other way around :D
Hard Kandy and PHD stickers used to be a boon for cops pulling over cars on a weekend morning :)
Haha agreed!
I'm trying to keep my car clean of stickers sorry guys! :)
I've only put one on myself and I have one which came from the last owner in Japan so I haven't taken it off yet haha.
Put the sticker on and represent, but only if you plan to drive responsibly! :blush:
thats why i put mine on :P to control my urge's of spirited driving :)
plus i have custom plates, so im just digging myself a hole if i drag every holden that rev's there engine at my wagon!
oh yeah and welcome to the club. its your 1st post. and your already paid up. good stuff
Of course you will man, where do you think membership money go's? To pay the filth under the table :blush:
So next time if I get pulled over, I'll just get out of the car and walk towards the back of my car and just tap on the SAU sticker and they will understand? :)
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
