well i finally picked up my rs4s :)
and i'm really happy
just a quick question about what fuel to run it on, i know 99% of imports like to run on 98 but under the bonnet i found this sticker (pic attached)
at the bottom it basically says 91-93 ron fuel
is that right? or is jap 91 ron different to aus 91 ron?
i intend to run premium but i will be going to tas for uni for 8 months and its hard to find 98 unless you are in a decent sized town
if someone can clear it up it would be awesome
Thanks,
Tom
https://www.sau.com.au/forums/topic/295974-fuel-question/
I was gonna suggest at first that maybe that Japan uses the average of RON/MON like America does:
(ever notice how Americans rate their octane ratings so much lower? ... this is why ...)
In most countries (including all of Europe and Australia) the 'headline' octane that would be shown on the pump is the RON: but in the United States and some other countries the headline number is the average of the RON and the MON, sometimes called the "roaDOctane Number" or DON, or (R+M)/2. Because of the 10 point difference noted above this means that the octane in the United States will be about 5 points lower than the same fuel elsewhere: 87 octane fuel, the "normal" gasoline in the US and Canada, would be 92 in Europe.
.. however, further reading suggests that Japan use the same RON fuel rating methodology as Australia/Europe/etc .. hrmm .. there goes that theory... I got no idea. I wouldn't run my import on anything less than 98RON.
https://www.sau.com.au/forums/topic/295974-fuel-question/#findComment-4932685
Part of compliance is "Fit Tune up Label" mate :happy:
so ignore it and run 98? or if that has been fitted maybe it has been tuned for 91-93?
:S
its got bp ultimate in it cos that was my first reaction (i've had a couple of imports b4)
might reset the ecu and see how it goes
https://www.sau.com.au/forums/topic/295974-fuel-question/#findComment-4933305
    • Well, in the same way that you can't tell any SUV from any manufacturer in any size category from any other one, "sports" coupes now all look identical. Stand back and squint your eyes and the Supra and the 400Z and the GR/BRZ things all look the same. I was just thinking last night, when sitting behind a Subaru CrossTrek, that I have no idea what it is, how it differs from an XV, or a Forester, or an Outback, or anything else Subaru offer, and I couldn't tell if it was supposed to be small, medium or large. I contrasted that to the good old days, where a HQ Kingswood had familial similarities to an LJ Torana, but there is no way that you could confuse them, and how a bit later, the HX Kinger and the concurrent Torana and the Gemini all had familial similarities, but you still could not confuse them. Ditto the ugly Fords and Chryslers of the era. But now, a RAV4 looks like a Kluger, looks like a Yaris/Cross/whatever they're calling those stupid f**king things, looks like every other Toyota that's not a Camry/Corolla sedan.
    • The Prelude doesn't look that bad without all that lens distortion in those pics. Makes it look disproportionate when it isn't. Actually I kind of liked it at the Osaka Auto Messe earlier this year.
    • Pour in the highest octane, non-ethanol fuel you can get and see if the readout changes. If it's dead bang on 11% then I would question the sensor. Another quick test, just take it out and run normal (in an american accent) gas-o-line through it and see if the sampled ethanol or lack of changes.   United E85 here in the land of drop bears does vary a bit, I've had as high as E87 (could be water in their tanks too, who knows)
    • Yep. And if you ever do, you'll just have to deal with it then.
    • E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane.
