  • Replies 55
While we're talking about wheels, I'd be interested to know what sort of max widths and offsets can be run on the 32 gtst.
I'm pretty certain i've seen 34GTR rims stuffed under the guards of a 32. Are they an 8 inch rim and whats the offset on these? Also what guard modifications are needed (if any) to fit them.
Personally, I don't think anything looks better on an R32 of any sort than R32 GT-R rims. R34 GT-R rims a close second.
*edit* those nismo Volk rims hadn't loaded...Very nice. Close third....
I think the best look for an R32 is a GT-R, black, standard wheels, lowered a couple of inches, big phat cannon muffler, rear wing removed replaced by one of those tiny little drag boot lip spoilers, otherwise externally stock. few wheels or body kit parts make any improvement on nissan's original work.
I'm interested too... how wide can i go without worrying about body modifications....???
I think someone mentioned something about the inner-guard too... what are the limits in height and width??
Ronin, your car looks sweeeeet!
Understated style.
You cant go past white wheels for a white car. I think 17s are good for R32s, but im a bit biased.
Ive got white SSR Integral 17x8s on my white r32, i think theyre pretty good for a cheapish wheel, theyre forged and i think their about $500 each new in japan.
Understated style.
That's times two!
Your shit is fly.
I love Buddy Club. I prefer the P1 QF - I can only find these pix on a shitty Civic:
http://www.aj-racing.com/BC-wheels.html
Here's my "old" car:
http://www.nitroware.net/~tony/r33_front.jpg
Here's my "new" car:
http://www.nitroware.net/~tony/r33_profile.jpg
T.
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
