  • Replies 55
While we're talking about wheels, I'd be interested to know what sort of max widths and offsets can be run on the 32 gtst.
I'm pretty certain i've seen 34GTR rims stuffed under the guards of a 32. Are they an 8 inch rim and whats the offset on these? Also what guard modifications are needed (if any) to fit them.
Personally, I don't think anything looks better on an R32 of any sort than R32 GT-R rims. R34 GT-R rims a close second.
*edit* those nismo Volk rims hadn't loaded...Very nice. Close third....
I think the best look for an R32 is a GT-R, black, standard wheels, lowered a couple of inches, big phat cannon muffler, rear wing removed replaced by one of those tiny little drag boot lip spoilers, otherwise externally stock. few wheels or body kit parts make any improvement on nissan's original work.
I'm interested too... how wide can i go without worrying about body modifications....???
I think someone mentioned something about the inner-guard too... what are the limits in height and width??
Ronin, your car looks sweeeeet!
Understated style.
You cant go past white wheels for a white car. I think 17s are good for R32s, but im a bit biased.
Ive got white SSR Integral 17x8s on my white r32, i think theyre pretty good for a cheapish wheel, theyre forged and i think their about $500 each new in japan.
Understated style.
That's times two!
Your shit is fly.
I love Buddy Club. I prefer the P1 QF - I can only find these pix on a shitty Civic:
http://www.aj-racing.com/BC-wheels.html
Here's my "old" car:
http://www.nitroware.net/~tony/r33_front.jpg
Here's my "new" car:
http://www.nitroware.net/~tony/r33_profile.jpg
T.
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
