Hey guys, I have an R32 GTS4 and i recently blew my little RB20DET sky high =P oops. (shitty oil pumps i say)
I'm wanting to get a new engine back in there, but obviously don't want to waste money on another RB20.
I was thinking of putting in an RB25DET manual out of a Stagea (or convert to manual if needed), but I was thinking was IS the difference between an RB25DET RWD engine and a AWD one? really?
From wot ive gathered it the sump studs in different places, but i could always drill that out and modify so perhaps a RWD RB25DET could b bolted straight in with sump modification into my GTS4, perhaps by modifying my RB20 factory sump or? Has anyone done this or heard about it?
It's obviously cheaper n easier to source a RWD RB25DET than one out of a generally newer Stagea, that are generally autos too...
If anyone could clear this up for me conclusively I will be extremely grateful!!!! =P
RWD RB25DET into GTS4 can it be done? I will do all the work myself with a mate including the engine swap. proficient skills. doable?
Thanks in advance,
Have a sweet one guys!
Really I would say you have 3 options, put another RB20 out of another gts4, put an RB25 out of a stagea AWD or an R26.
Converting to rwd is rather silly as you would be pulling out all the front drive, then replacing the suspension (at least a few parts) with gts-t items. In which case you probably would have been far better off putting another stock RB20 in and selling the car and just buying a gts-t :(.
Wouldn't one of the adapter plates the GTR guys use to put RWD RB30's into there machines work? Probably expensive'ish, but once you are over the initial hump, you can always use cheaper RWD RB25's. Those are like $300 back on Okinawa, but I assume a bit more there. Are stagea RB25's hard to find/expensive?
Cheers guys!
The reason i ask this is because i have the tools n drill bits to easily be able to modify my RB20 AWD sump to an RB25DET RWDmaking it arguably easier to source and cheaper for me than a stagea 25. However some other kids have said u can pickup stagea RB25's cheap now, and I was assuming they'd b at least $2-3k, hence why I was thinking about modifying my sump. But apparently they're going for ~$1200 so i'l most likely go with that obviously! Still, I would like to know for general knowledge if it IS just the sump that's different between the AWD and RWD RB25's, i assume so at the moment but enlighten me if that's not the case =P
Thanks again, have a sweet weekend guys!
Edited by WhatBrake
you couldn't have tapped the holes in to the RWD block anyway because the 4wd blocks have a wider sump flange to fit the wider 4wd sump so you would have had to buy a 4wd adaptor. The 4wd blocks do have both sets of holes though, both 2wd and 4wd.
TRUE. I was wondering this, my mate said he knew the AWD had both sets of holes. But i wasn't sure if they did the same on the RWD's. Yeah so it looks like I'l need an adapter, which is what I was asking. Do u know how much an adapter would set me back? obviously if it starts adding up it may negate it being the cheaper/easier option. Still undecided depending on a few things, but stagea 25 prob b the go. Ive heard the neo can b anal with trans control or something? non-neo stagea RB25DET straight in. N could i bolt my RB20 sump onto that RB25 neo, or would this just be a waste of time?
Cheers guys.
Edited by WhatBrake
just by that c34 engine off ebay. you can't go wrong for $1150
I just despise buying stuff like that off Ebay...Oh I see it's jdm performance. Good call. I'm assuming things - private seller.
Thanks! :P
Edited by WhatBrake
Did you use a 34GTT ecu?
The adapter plates are close to $1000 with a new pickup (I thought about mentioning this in the other thread but the costs aren't worth it unless going 3L.. rwd 25 + adapter > stag 25).
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
