Not really, When i was on my p's i head a cooler,exhaust, podys,bov's car to low etc... i use to get pulled over by the same officer and he would just dick me for the same things when i take them on and off.
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4934462
No, same again. Maybe go about it a smarter way though, get a turn back cooler so there is no hole, leave the airbox in and don't put the blow off valve back on. Get a decent exhaust that isn't too loud and you could even hide a bleed valve (I did). I also put a Power FC in and screwed the stock Nissan ECU faceplate on (tight fit but you can).
As I said, this time go smart and they wont get you, they never got me again :(
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4934538
What did you do with the HC? Or do you not have one?
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4934578
Hand controller need not be connected all the time, and you don't really need it unless you're tuning on the side of the road...ala this guy:
http://www.youtube.com/watch?v=ojB7KkaR03I
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4934842
recently i got a canary for my exhaust, intercooler, bov etc.. i removed it all, patched the hole and is now stock..
is there a harsher punishment if i get dicked again with the same mods?
cheers,
mate 2nite i got the most fkn bullshit defect. exhaust too low, fair enough i dont mind getting it raised and a rwc. that would have cost me $60. instead he lists it as a major defect and a $300 fine. WTF? i was done 20+km over the speed limit and the fine was less that that. also, he didnt tick the RWC box. since when is height a major defect with such a fkn huge fine?
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4936710
Its up to them to decide whether major or minor whether you get a fine or not and also whether you get points aswel, ive always gotten major defects and all with rwc, theve given me a major just for pod and rwc and fine, it depends on how much of a tight ass the cop is and yeah with the exhust being to low they love that on skylines always check that first , i got a major for being a couple of mm to low with a rwc like i said depends on the cop
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4937609
I was under the impression that the law was "lowest part of the vehicle no lower than 100mm above the ground (maybe it's 90mm can't remember) so yeah it's a defect but Major, I suppose it depends how low it is
yeh i think hes just another of those racist f**ker cops. din bat an eye lid at all the holdens driving past over the limit with exhausts that sound like a fart in a milo tin but once he saw me he took off like a bat outta hell to catch me
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4937613
not always, a lot of mods can be considering minor or major depending on the cop and the driver. major is usually safety wise, ie, bald tyres ect. major for too low is a dick move unless springs are cut. then its understandable.
Edited by Peter89
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4937934
Were you doing 20k over the limit when you were busted or are you saying the fine for doing 20k over the limit is less?
The defect is at Police digression, if they want to ream you they will. If they see previous offences etc they are more likely to ass f@*k you.
I didnt kno aftermarket ecu's were defectable..why is that?
Yes, it's due to emission laws. If you alter air/fuel etc then you change the emission's.
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4938626
Ohh,i didnt kno cops actually looked at them for defects,,lol dodgy dodgy..
but doesnt that make it illegal for apexi to sell pfc's or haltech to sell their units in australia?
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4942863
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
    • These look like S13 wheels.  And Welcome!
