The driver I imagine...it's not illegal to install on a street car. Drive the car on the road and it's a different story.
But a cop is getting desperate for EPA revenue if he's sitting outside RE customs with a roll of canaries waiting to pounce.
Unless you like to show off the Apexi logo on your PFC, just bolt the nissan OEM ECU faceplate onto it
most cops will be none the wiser as long as you dont have the handcontroller plugged into it
yeh someone told me u can fir the stock ecu plate on it but its a tight fit, yeh i think only the hand controller wud give it away. but wud b funny trying to unplug ur stuff and hiding it wen u get pulled over, seeing as cops see everything :)
yeh someone told me u can fir the stock ecu plate on it but its a tight fit, yeh i think only the hand controller wud give it away. but wud b funny trying to unplug ur stuff and hiding it wen u get pulled over, seeing as cops see everything :action-smiley-069:
don;t drive with a hand controller plugged in
do you tune your car while driving to have it sitting out on the dash? or plugged in at all?
The only reason you'd need a controller is to tune the car or watch the temps and stuff.
I wouldnt be surprised if something like that hapened though, the government does want that import owner's money
No they won't.
It will hurt small business.
The way it is - leaving as is. Wait till they leave, rather than be discouraging out the front :action-smiley-069:
Business gets their money, then the Gov't rapes you after it's all done with its archaic laws for money a week, month down the track.
If they cut it from the start there would be less overall.
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
