Hey guys I have this for immediate sale:
Blitz SBC Spec R (Dual Solenoid Boost controller)
Uses the same Solenoid as the Blitz SBC ID - III (I have both, upgraded to the ID -III because it shows more information on it's display.), Blitz Dual Solenoid Boost Controllers are renowned for being some of the most accurate on the market
The Dual Solenoid Boost Controller Spec R (DSBC Spec R) has four programmable boost settings or various levels of boost. This unit features a built-in boost gauge, peak boost display, four different boost settings, boost warning, scramble boost, and a boost limiter safety feature to prevent over boosting. The DSBC Spec R uses a dual solenoid design for maximum boost response. This unit is capable of handling boost up to 2.5bar (36psi). The DSBC Spec R is 1/4 din in size and is compatible with internal actuators and external wastegates. This unit is available in a silver case with an green LCD display. The difference between the DSBC Spec R and Spec S is the solenoid design. Spec R uses dual solenoid while the Spec S uses a single solenoid design.
*Note: Model on Nengun has an updated look from the one that I am selling, the information above is taken from the "updated look" model on Nengun and so may not be exactly applicable to the one that I am selling. From my experience with the unit it sounds very similar.
Nengun price AU $473.75: http://www.nengun.com/blitz/sbc-spec-r-dual-solenoid
Condition: Used, Good.
Asking $280 + Delivery costs.
Also have the following items up for sale when I get my car back, approximately 2 weeks:
Blitz Racing Meter DCII - Boost (Gauge) - Blue:
The electronic Racing Meter DC (Digital Compact) II series are one of the most unique gauges on the market. Succeeding its predecessor, Racing Meter DCII maintains the traditional dimensions and versatility of the Digital Compact Series - Featuring a depth of less than 1-inch and weighing 38 grams, the Racing Meter DCII can virtually be mounted anywhere in the vehicle. 60mm Diameter.
- Peak Hold: Peak hold can be shown all at once or by individual gauge.
- Record and Replay: Can record and replay up to 99 seconds.
- Warning: All you to set the warning for the gauges.
- Mode: The DC Meters has 3 different needle modes, real time, delayed mode and pass and hold mode.
- Contrast Adjustment: Allows the owner to adjust the contrast.
Nengun Price AU $ 245.08: http://www.nengun.com/blitz/racing-meter-dc-ii-boost
Asking $100 + Delivery Costs
Needs to be coupled with:
Blitz Racing Meter - Live Unit II:
Live Unit: The Live Unit can control up to 3 gauges; boost, temperature and pressure. The Live Unit also has an addition temperature sensor outlet, this will enable the user to purchase an extra temperature sensor and let the Temperature Gauge read two different readings.
Nengun Price AU $ 154.52: http://www.nengun.com/blitz/racing-meter-live-unit-ii
Asking $60 + Delivery
*I am unwilling to separate the Boost Gauge and Live Unit at the moment, as they will only work together*
Rays Engineering Dura Wheel Nuts - Regular Type - Blue:
These do not come with Lock Nuts, just 20 normal Rays Wheel Nuts.
Just like their wheels, some of the lightest wheel nuts in the world, perfect for your TE37's
JJR Price AUD $275.00: http://justjap.com/store/product.php?produ...at=0&page=1 (No listing on Nengun, only Short or Long type.)
Condition: Used, average (See picture above, rattle gun damage.)
Asking: $90 + Delivery
I will post more pics of the actual Boost Gauge, Live Unit and more of the Wheel Nuts when I get the car back
PM me if you are interested.
harts.
ECR-033: Thanks mate!
Dilmah: As stated in the original post, pics of actual boost gauge will go up when I have retrieved it from the car. Car is in Body Shop. I'll try and rip it out mon/tues and post up pics :P
Boost Gauge & Live Unit Pics:
Boost Gauge needs to be zero'd when it is installed, following the procedure found at the bottom of the last page in the Blitz DCII Manual, found here:
http://www.blitzpowerusa.com/techsupport/pdf/rm-dc2.pdf
It reads:
Note: Regarding the Boost Meter.
There are times when the needle/pointer on the boost gauge may not return to 0 after the self test.
To "Zero" in the gauge, hold down PEAK and REC switch on the boost gauge when you turn on the ignition. All L.E.D.s will light up. Use the PEAK button to raise and the REC button to lower the needle/pointer to the proper location. Push the MODE switch to exit programming and return the gauge to real time monitoring.
harts.
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
    • Well, moulded carpets should fit well if the buck they use is the right shape. The finish is then just a case of stiching the trim around the edges. Shuoldn't be too hard to get it right. Back in the day, replacement carpets were all "fitted", in that they were stitched together, with cuts and slices taken out to make them form the shapes. Many more opportunities to get it wrong, hence all the concern over good vendors and bad vendors.
    • A timely blog via AASA (keeping in mind they sell brake fluid of course...) https://www.msbgarage.com/blog/news-and-blogs/brake-fluid-what-should-i-use/
