  • Replies 60
nismoid is going off 98 you are going off E85. whats the point of the argument?
I'm not sure he has one to be honest. He knows full well you wont make the figure on PULP, the ole smoke and mirrors trick perhaps?
PULP is what everyone talks about with regards to fuel, power output and requirements unless otherwise advised.
If someone makes more power on a specific fuel (which happens), it is clearly stated.
Everyone knows E85 is not a commonly accepted fuel, it is no different to any other boutique fuel and is irrelevant to 99% of applications discussed here on a daily basis.
If the OP is going to use E85 then of COURSE he will make 360-370rwkw, and i would agree with that.
Anyone will tell you that as its the typical 40rwkw gain from using that fuel.
However E85 was not stated as a requirement or part of the scenario, nor is the equipment list supplied upto the task. So one of course assumes the norm, PULP.
Every power estimate thread, every "what will this turbo make" thread all assume PULP.
News to me if E85 is now a commonly available fuel.
Cerbera just enjoys trying to make people he doesn't like look silly any chance he gets, must be some kind of childish game those WA people play from time to time, but that's ok as long as i get to play too. :P
700cc injectors says that he won't be making 350rwkw on E85, they're not up to the task. Dave (NYTSKY) is on 1000cc injecotrs now, and so is Anthony (Guilt-Toy) I believe. Anthony also has a 3L bottom end. And I don't think he's running a 3076R, I thought it was a 3540...
So with the combined facts that a 3076R won't make 350 unless on E85, and the fact that 700cc injectors won't run 350 E85 rwkws, and that the original poster never mentioned E85, Nismoid is right.
That turbo, with those injectors, and either fuel, will not make 350rwkws... E85 will get you closer, but then you will have to up your injectors...
Sorry to detract from the entertaining argument... but assuming capable engine and appropriate head work etc from an RB26, would it be possible to make 350kW or more using N1 turbos or GT-SS's (or Garrett equivs.) taking advantage of the higher octane of E85 with timing etc...?
Mike
Fact. A GT3076 will not make 350rwkw on PULP. Nor will it make 360rwkw, or 374rwkw on PULP.
That may depend on dyno....
Shows how ignorant those with the incorrect facts really are.
Was this a dig at me? Not sure what you think of me but I try to help cut through the shit where possible.
^ lol no dude, not you :P
Mike
I reckon you should be able to do it, there is no reason you can't. Same would be said for any other boutique fuel - Martini, Sunoco
If you can get 320-330rwkw from GT-SS's on PULP, then you are looking at around 360rwkw give/take?
Every result i've seen from E85 skylines, EVO's, WRX's - once you get to the 300rwkw marker, to approx an extra 30-40rwkw.
Just gotta remember the offensive fuel consumption of course.
So you could probably apply that percentage to below 300rwkw and workout the gains there as well, should be "near enough" for the intents of results projection
not at all, love a good debate and dont like people slinging "facts" that may not be true!!!
OK to summarise this thread.
1. A 3076 .82 will get you there however you will need to run E85 and your injectors will need to be upgraded to 1000cc items and upgraded fuel pump to reach your desired hp goals.
2. If however you are prepared to accept a laggier setup a GT35 will acheive your power goals on PULP and you can retain your existing injectors.
3. Members from Perth don't get on with members from Collingwood. :P
just to stir nismoid up a little bit more...
joeyjoejoe just made 320rwkw with 555cc using E85
now my maths may be a little off but does that not translate to 700cc injectors capable of 403rwkw :laugh:
OUCH!!!
Oh snap.
ps. on topic, go a GT30R, you don't need massive HP for drift, instead you need lightning throttle response, a 35R will take too long to spool in your application.
3. Members of the human race don't get on with members from Collingwood. :blink:
Fixed.
Cerbs is wrong ... as usual .. hehe :)
If its PUMP the gt3076 it won't make 350rwkw ... lets see some TIME, WEIGHT AND MPH to back a car that has ?
It its E85 far out run the GT35. If you understood E85 you would know why ..... oh wait you don't have a car tuned on E85 do you cerbs ?
Just FYI b4 mods freak, having a friendly rib from one Simon to another !
You will get around 375rwkw depending on rail pressure and your chosen AFR.
Agree 100 %
Disagree 100 %
Disagree 100 %
Simmo, I know you have had the 35R like I have, but you've used it in a drag application.
On the track, I found the 35R to be a bit lazy when coming on/off the throttle.
You can disagree all you like, but thats just my experience :ninja:
Hey Brockas :D
There a few points around this discussion.
Our setups are not apples and apples. As you have a china mani and t4 rear. So I would expect yours to be more laggy.
One interesting thing we both have is the OS gearset ratios. Man they do make 1st n 2nd feel a bit laggy when your caught off boost.
Remember we are talking drift(not track or drag) which neither of us have actually done. So I am using Bangers setup as an example.Its an RB25 and gt35 turbo and yer we both know he's one of the top level performers in perth.
An rb26 would be better again !
Finally for track setup, yer I would use E85. Thats a whole new world again !!
Hoping to one day soon, get my car on the no limits night. So find out for myself what you mean.
Guess again it will be different though as my car is a lot lighter. I just need to get a sway bar fitted to my car lol.
banga is a invalid argument, his rpm range is between 10rpm below limiter to 10rpm above so respnonse isn't really needed :(
i remember sean talking about tuning the various wa drift rb25 powered cars and they all make a bit over 400rwhp on his hubber with the 3076R's making shit loads more mid range that the 3582R's
Hey Brockas :(
Yup all valid points, except I'm running a stock gearbox now (after breaking the OS) and it actually makes it feel a lot more responsive than with the gearset.
The on/off transition of the 35R isn't bad by any means, just don't think it feels as sharp as a GT30.
maybe you need to harden up then and stop whining about lag and CLUTCH CLUTCH IT !! hehe.
Ahh yer forgot about the broken box :(
At the end of the day I reckon I agree with you. Big power isn;t really needed for drift. More time should be spent on car setup and driving skill :) (ps I have none) The GT30 will have plenty for sure.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
