Noob question but what makes the V8 Super Cars faster - do they have better tyres?
Professional drivers for starters. The cars are setup for that style of racing too...however, to be fair, you also need to take into account the restrictions a V8 supercar has that give it a disadvantage around the track: minimum weights, maximum brake rotor size, rear wheel drive configuration, they're based on the chassis length/configuration of a 4 door sedan, control tyres. Also, unlike sprints, in a racing environment achieving your best laptimes is the last priority. Top 10 shoot out is about as close as you get to that. So although fun to compare times it's not too relevant outside of the homologation.
Pretty cool times in the R35 OP, well done - I look forward to seeing the vid. Bathurst is a truly unique and awesome circuit.
V8 Supercars are genuine race cars. They have no relationship to the road car what so ever. The fact that they look similar is almost purely coincidental.
Yes they do start out with a road car but the amount of chopping and custom fab that goes into them is genuinely staggering. The front ends are hacked and replaced with custom suspension geometry, as is the rear, and there is one monumental buttress fitted to the rear end to handle the massive power levels. Their floors are completely removed and replaced with custom built in house jobbies. The driver's seating position is moved almost to the middle of the car and the race engine is moved much further aft than the road car.
On top of that, this years 888 falcon did not share a single external panel with the road car. The Ford and Holden stickers are there for little more than sponsorship.
That Holden and Ford can claim victory for the hard work that each individual team undertakes is nothing short of a joke.
Anyway, add slick tires and closed loop chassis tuning and there is no chance that any road car will ever keep up.
I'm sure the V8 is still lighter than the R35, brake would definately bigger too, power restriction.....??? I think they make around 600kw@tread and run 10 :blink:
I thought this was no longer the case. I've been told the V8 supercars are actually bigger than their road car cousins and really they are a dedicated race car that is shaped and painted to "look" like the road cars...but the resemblence stops there.
The V8's on qualifying laps get around 2:08 and sometimes high 2:07's but when you consider the differences between them and the R34GTR, that 2:13 is very very impressive. nice work!!
I'm sure the V8 is still lighter than the R35, brake would definately bigger too, power restriction.....??? I think they make around 600kw@tread and run 10 :D
Not quite, about 400-420rwkw, capacity and compression limits. Pretty sure brakes are 380mm, same as r35
  • 4 weeks later...
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
