Front Mount Installation With No Cutting Holes
hi guys, ive had a FMIC sitting round for a while and i think its time to have it put on. i want the piping to go back around the cooler, rather than have a hole cut so it will be road worthy.
can anyone recommend a good place that will do this and if possible tell me how much it will cost? it can be anywhere in melbourne i dont mind. as long as the place is reliable.
so ive spoken to several places in s.e suburbs, a few who said its not possible to do it without cutting a hole, for which i said thanks for your time aka get f**ked u noobs. prices seem to vary from $350 to $1000
get a blitz return flow kit, or the just jap one,,needs no cutting, just need the reo trimmed to fit the top of the cooler.
but if u do wanna use your core(assuming it's just a normal core), you'll probably need to get someone to make a U-joint to connect up with the rest of the piping..
But i'd jus go with a full blitz kit,,then just sell your core
i think the jusjap ones cost about $400 for the r33 one, not sure about r34
Yeh if you wana go that option its not bad, im doing 230+ kw's with my just jap & blitz return flow cooler. I broke my blitz return flow core so now using the just jap and they are just identictal! fits up nice
you can purchase them here:
www.justjap.com
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
