Hi All,
Was just wondering what size the compliances cats are in our cars? Im thinking they'd be 2.5" hay? Ive got a full 3" system with a Hi-Flowed compliance cat :P .....
If its a 2.5" flanged cat it would be the equivalent of having a baffle plate in their and hold me back a bit would it? Would it be worth pissing it off and getting a 3 inch flanged cat and "hi flowing" it :D
https://www.sau.com.au/forums/topic/296205-compliance-cat-flange-size/
Has it been "hi flowed" properly? They should have a pipe sleeve running through the middle. If not, the change in internal size will be a restriction. You'd be better off with a quality Hi flow 3" cat, they don't hurt power that much. And it's all legit then :P
Note; No responsibility will be taken if you use this post to render a cat inoperative. It's there for a reason, if you're that worried about the extra couple of hp, turn off your aircon, or go on a diet.
Be aware that the EPA in NSW do trawl the forums looking for just this type of post to find people breaking the law.
Chris, I bought a 3" Catco one from JJR - at less than $220 delivered, you can't go wrong.
Yes, the ID of the flanges is 2.5", and a 'gutted' cat does screw up the flow - simply by being an awfully shaped vessel.
If you really don't want to run a cat (remember that it is a Stagea, not a 400R :sick: ), get a decat pipe (for the track) or one of these:
http://www.frozenboost.com/product_info.ph...products_id=320
When I hi flowed it, it upped boost and was providing smoother power (used to have a bit or jerk). Many mixed opinions on gutted cats from different mechanics and stag drivers. Im more for it but I may get a catco then and prob bash its guts out aswell.
Get a Catco 3inch cat but don't bash the insides out, it wont make any difference. Only thing you'll gain from no cat is a dirty stain on the back of your car. Hence why i still run a cat in my 300+kw skyline on the street.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
