my gearbox is out of my r32 gtst because i have just relpaced the clutch
i have the car up on stands in my driveway and dont have a trans jack, me and my mate can manage to lift it up enough however when we try to lift it up it seams the trans tunnel is to small to alow you to riase thye box far enough back from the clutch pressure plate to clear it.
for those that have done this before could u give me any tips??
cheers
-Alex
https://www.sau.com.au/forums/topic/296208-puttin-gearbox-back-in-32-gtst/
Too much information, mongor!!!!
You shouldn't need to force the engine backwards. If you disconnect everything correctly, the engine should just roll back and rest the back of the rocker covers against the firewall.
i agree with the slight jack up of the front of the engine works wonders.
but at the same time it can be done without doing anything, but it took me 2 hours just to get the box back in the first time and it was the last time i changed a gear box on the floor.
I used a trolley jack hold the majority of the weight of the gear box while my mate I got it at the correct angle for it to slide in.
It's even worse with a 25 box..
As mentioned above, gotta put it in rotated.
With the 25 box I have to go as far as dropping the engine crossmember about an inch (as far down as it will go wit the nuts still having purchase) but this is also due to the bigass fitting at the back of head.
alright thanks guys, well the gearbox crossmemeber is stil attatched to the box so i guess if im going to rotate it i will have to take it off, or i might drop the crossmember, if its not to hard.
I vote for jacking up sump or even the front pulleys, but use wood so you dont damage anything.
once you have the box on and you cant get it close enough at the top to get those stupid top bolts in you can place some wood or a stand under the front of the engine and jack up the back of the gearbox so they oppose each other and then you can chuck the bottom bolts in and the the top will close up by itself under the strain :)
This saved me a lot of time when putting in the gearbox by myself (no friends)
Edited by Jap4life
sounds like a good tip,
i scored a trans jack from work, woop woop, just wish this rain would stop, workin in a river aint fun.
when it stops ima try puttin the box in upside down n then rotating it onces its on,
if that doesnt work then ill try jacking the front of the sump and or loosening the crossmember abit,
no doubt that wouldnt be fun without a rattle gun tho
ok guys its all in and the cars back ;)
thanks for the help everyone, in the end i had to do everything, drop crossmember, loosen engine mounts, jack up front of sump, and then put the trans in upside down then onces the front of the input shaft was just inside the clutch plate i was able to rotate it so that the bellhousing was lined up n then a bit of wiggling and the box went in :D
cheers everyone
and those top bolts were a piece of piss with the crossmember dropped and stuff, should have done it all like that in the first place, only bolt i struggled with was the top starter motor bolt, just took ages, 1 click of a ratchet at a time lol
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
