  • Replies 160
Pardon my banana bender question guys but what is a hook turn?
You make a right turn from the left lane so that you don't hold up trams.
Hope this helps ---> http://en.wikipedia.org/wiki/Hook_turn ;)
Its actually really smart :(
That is, if you have trams running down all the streets of the CBD like we do. Makes traffic flow very nicely in a confined space.
lol @ the fat pizza explaination, i forgot about that :wave:
First time driving in the city, never been taught one. No trams where I live.
Then make it a point to learn. You really shouldn't have a license in Victoria if you can't do something in the city which is reasonably essential to know. I'm sorry, but a hook turn is a very easy concept.
Fact of the matter is I would've been more than understanding and deserving of being booked for that, rather than drag racing/speed trial.
I live on the NSW side and currently have my licence there... NSW dosen't have stupid BS road rules like VIC does.
I also live 550km from Melbourne CBD - I'd be willing to bet that there would be a fair few people around here who can't do a hook turn. I've done one successfully once (I think), but it and the whole tram lane thing in general is hard to get your head around when you're not exposed to it all the time and/or from a rural area (or moreso in my case come from another city where trams are non existent) where you never see anything of the sort.
I can understand if the OP was maybe 'hooking' it a bit lol, I know I was when I tried that particularly stupid technique, for fear of being stuck in the intersection or hit by an oncoming car!
Edited by bozodos
I know from personal experience cops word > your word. Even when the cops exaggerates ridiculously. The courts look after their own, even with a decent lawyer you'll have a rough fight on your hands.
ask a lawyer if you can get the contact details of the other drivers somehow.... if you all have the same story it would be a lot better
I know both of the drivers in front, and 2 out of 3 had a passenger, so that may or may not help.
Called up asking for the CCTV footage today, the head of security in melbourne was not very helpful, smart ass at times - "we don't give out the footage to everyone" i said "I completely understand that mate" he replied "maybe you just want a picture of some cars drag racing in the city" so i said look mate I can just get them under freedom of information act and he goes "yeah takes 3 months for that to get processed....we delete CCTV after 28 days, so go for it"
After he got off his high horse, he said he'd have a look down exhibition, bourke and russell for me to see if there was anything but no promise as the cameras might not have been facing the road.
If i was you i would hurry up and get a lawyer, things move a bit quicker when requests like that come from a lawyer.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
