Hi All,
I've just noticed in my R33 GTST the fuse box in the back is labelled with "30A 4WD/LSD", Why would they bother putting this in a 33gtst, it's probably just the same fuse box for all models I thought. I popped the lid off and to my surprise found a fuse installed in it's spot. Also in the boot as well as the normal HICAS ecu I have a second one bolted on to the bottom of it which is connect to a factory looking loom, one other 33 owner I asked seemed to think he only has 1 ecu in the back.
Does it all mean anything?
Thanks.
https://www.sau.com.au/forums/topic/296228-r33-4wdlsd-fuse-why-do-i-have-it/
Might have an active LSD, was an option for R33 GTS-T's: http://www.skylinesaustralia.com/forums/R3...or-t268134.html
No LSD/SLIP lights on my cluster, no reservoir in the boot, no finned diff cover, also no mention of the alsd in FAST.
It could be a 4ws electronic lock ecu? Where do the wires go? Hard to see.
Interesting theory :)
Wires run in to a factory looking loom, along the backside of the seats until finally entering the main cabin on the left side, by the direction they head off in possibly to the main ECU, does not appear to splice in with the wiring from the larger ECU.
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
