Superlap 2010 Ramblings
Certainly seen bigger digs lol, Thanks for the heads up. Appreciate it
Sorry to dig up an old post, these seats do not sit inline with the steering wheel so expect them to be offset towards the door. Also they sit a lot higher than the factory seats. There is a datasheet available online that confirms this. Can also advise be careful who you purchase from if you get them from a distributor in Australia, the company I purchased from in Sydney is no longer listed as a Bride distributor and I understand why, there was zero support from them.
You weren't kidding about the long block, what a difference it made!! I fixed every dent almost and all of them except for one and it feels 100% smooth on the others! I just need to fix one up and put some guide coat. Thanks a lot, that was game changing and time saving.
I got a quote to refurbish some BBS look-alikes -best part of 2k. I had some alloys sand blasted - bad idea, in retrospect. Had to wear gloves to handle them! I had them powder coated to protect the rim. Rather than sand blasting, I recommend hydro blasting (blasted with micro-fine glass beads carried in a water stream). I had a set of TRX rims done recently for only about $200 total.
