  • Replies 1.4k
Posted Images
isn't that Friday the 21st? competition Saturday 22nd?
Now im confused - from the assigned 5 sessions - surely a couple of these would be practice and surely on the Fri? or maybe 1 session per day?
http://www.superlap.com.au/2009/?p=2278
Edited by HKS26T
Thanks for that Steve. Pity there isn't one closer though, was really hoping for an open day on the 19th/20th.
Harry: I think both days are competition mate. I was hoping to get a good day in prior.
Some bling bits just arrived for The SLot Car.
We discovered this billet alloy dry sump set up made in USA for our VQ30 twin turbo motor we are fitting. It is a girdle, sump, oil air separator, dry sump pump and oil filter bracket all in one. THe motor will be more reliable, help piston rings seal better, less drag for crank, both indirectly making more free power. so more power, less weight in front, as oil tank will go in left rear of the car. Also allows us to move the engine further back and lower, lowering the weight in the car, allows us to raise the steering rack to get rid of bump steer, rather than spacing the outer steering pivot point down. It also allows us to run a better front air dam in under tray, as has more clearance.
The new motor should have us well under 1150kg and much better balance front to rear and left to right as mounting the oil tank left rear allowing us to remove 10kg of lead.
Cosworth Plenum on way.
6Boost making exhaust manifolds and GCG supplying turbo's.
wow sub 1150kg sure is light! :P
When we do carbon fibre tailgate with Perspex window and carbon front bar, it will be well under 1100kg. Then have plans for building a 3.8 litre VQ with VQ35 crank and Darton Sleave kit, which we have, and will be easy 500plus rwkw, maybe for next year. Also have plans for custom Chrome Molly front suspension, getting rid of the heavy king pin and upright, this should save many kilos off the front suspension, through in traction control and looking at Ikea Sequential shift kit with ignition kill and we might only be a mile away from the big guns rather than miles.
There is a ARDC supersprint the weekend before on the 16th is a round of the CAMS Supersprint Championship, would be hard to enter unless you are registered in the Supersprint championship as you get first preference, but worth a shot. I will be running the Mazda R100. When i get entry forms will let people know and then you could contact the ARDC.
Thanks for that mate, would really appreciate it.
John: Z sounds like it's coming along nicely, should be even more of a weapon soon.
So I hear on the grapevine that the Scion is coming from the States!
It's apparently now up to 1200hp and has undergone a 4WD conversion with a custom billet alloy cased gearbox! I also hear he's flying the thing over! haha
I think the entry list is nearing 10 internationals, which would be awesome!
I was giving some private tuition to a couple of guys yesterday at the creek who are both running in clubsprint. Far out, there are some fast cars around. R33 GTR in clubsprint spec doing a 45.4 on a hot day is not mucking around. Also good to see Lofty out there with the BSM R32 GTR doing some serious testing. They were pulling 280kph down the chute and were well below the 40 sec bracket :D
Alright whos the one spreading rumours a Viper and Mustang are coming over aswell from the states???
Not happy...got all excited only to bfind out its not true! :cool::cool::D
P.s should get Tacker to come over! :/
    • The exhaust gases are at their highest temperature as they leave the exhaust port and enter the manifold. They cool as they flow through the manifold because they transfer heat to the manifold and the manifold loses heat to the surrounding environment. Thus, inevitably, the exhaust gases are cooler as they enter the turbo compared to when they entered the exhaust manifold. So, yes, the exhaust manifold can easily get as hot as the turbine housing. Having said that, you will generally see the highest temperatures where the exhaust gases have to slow down or they are concentrated into one area - which is usually the collector on the manifold and in the turbine housing, because the gases slam into the metal at those places, increasing the convective heat transfer coefficient and transferring even more heat to the metal than they might just flowing past elsewhere. Exhaust manifold heat shields are a good idea - certainly for the stock manifold they are there from the factory. People seldom have anything like that on a tubular manifold because they are hard to achieve. Some might wrap a tube manifold with fibreglass tape - but this has a reputation of leading to cracked welds. The best case is generally to put ceramic coating onto the manifold to prevent it getting as hot (internal coating) and radiating/convecting heat into the bay (external coating). All the real heat from a turbo comes from the exhaust side. The gases entering are at ~800-900°C and the steel/iron gets nearly that hot. The compressor side is only going to heat the charge air up to <<200°C (typically not much more than 100°C). So that's nothing, by comparison. The compressor is not a significant source of engine bay heat.
    • Late to the party, specifically joined this forum as I just bought one of these and this thread has been a gold mine of info. If the OP is still around, mind if I ask what gas you been putting in yours? Mine has a Japanese sticker in the cap saying premium but it seems to get way worse mileage on premium (95) than 91. I always thought it was meant to be the other way round🤷 I do think Nissans claimed "6l/100km" is a bit fantastical 😂
    • Does exhaust manifold get hot as turno exhuast side? I have a turbo cover to managr heat in the engine bay but  nothing is covering the exhaust manifold before turbo   i know as turbo does compress air, the temp does go up however does that mean exhaust manifold would be as hot?
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
