Is spectators allow? If so how much is gate entry ticket? Anyone know a decent hotel near by?
Thanks
go to superlap.com.au and the prices are there. If you order them online before the 13th you get a discount on entry.
no idea on hotels around there.
  • Replies 1.4k
Posted Images
its easy solved just run less front torque. the rear diffs are pretty much indestructable (only about 5% smaller than ford 9") and the driveshafts are OK but casn be upgraded.
the problem is....the more fwd, the quicker they go....so in an event like this they have to run 50/50 and hope for the best.
plenty of options for driveshafts, just jap even have billet stuff on the shelf. its the front diff that is the big issue.
where is lofty....how are you guys going with front diffs....you guys have by far the most experience with trying to put big power thru the front in circuit use.
bingo! duncan has hit it.. like you say it's easy fixed by less front drive and kinder shaft angles but then you'd end up with a standard height GTR with lots of oversteer and nice and slow...
like lofty obviously knows too basically the more front drive you can dial in the faster you go. downside is cvs breaking and if you beef them up then expect to bust a front diff or two out of the case (marks done that before but not in the 34). and with the front diff being housed in the sump assembly it's not something you can easily strengthen. maybe a full custom CNC billet sump would do it but fark I can't imagine the complexity of machining and the cost. my god man the cost!
everyone has been there and done it. garage saurus run their famous orange time attack GTR in full time 50/50. wont tell me how they get diffs to last but I imagine they limit front drive under braking too like dave explained.
as benno says mark has it well sussed with a similar system. this particular failure could be down to anything.
I hear the Panspeed RX7 is in a container and on its way, after receiving a nice freshen up, including a new Hollinger (replacing the Hewland) :happy:
More;
http://www.superlap.com.au/2009/?p=2948
Edited by Marlin
Me too mate, great things to drive :P
We're on the hunt for somewhere to test Hollywood's 32 after it's rebuild and new Hollinger in a couple of weeks. Lakeside or Morgan Park most likely. I'll make a point of checking the brakes too. :happy:
go the RWDs! The RX7s are carrying my hopes! Will be intersting to see how the NSX goes too. but the 900-1000bhp falcon I can't imagine being very competitive. Would have been better off keeping the V8 donk and spend as much time as possible tuning the car on those tyres at Eastern Creek I reckon, rather then building and fitting a kick ass I6 turbo motor.
And it would have been nice to have a NA V8 in Pro class.
pan speed RX7 is turbo, not NA 20B.
the pan speed car is one of my favourites. some pics I took of it at a Tsukuba hyper rev event. they are nice guys too.
I love the interior!
one nasty rear end!
I reckon the pan speed RX7 will be in the top 5 for sure. it's a very quick car and a good team behind it. It will be one of the quickest RWD that's for sure.
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
    • OK, a few half jobs on the skyline this weekend because its booked for a test day at Wakefield Park on 27-Feb. While the Ecutek dongle and app provide display and logging of a heap of engine parameters, they annoyingly don't have access to the auto trans temp. So I grabbed an oil temp gauge from Raceworks which apparently has warning colour change and peak hold, about $95  and their 8mm hose sender adapter Now, I foolishly thought these 2 might work together, but no, the sender needs about 30mm clearance in the fitting and the adapter only had about 8mm. I've cobbled something together with an NPT T piece and blank for now but will try and work out something more permanent as I intend to use the same fitting for the data logger in the future. Under the car, Nissan's engineers decided that only one opportunity for coolant and trans fluid to mix (the radiator) was not enough, and they also added an interwarmer near the sump on the passenger side like the engine oil has: I've cut the hose between the auto trans outlet and the interwarmer inlet and inserted the sender there as that gives the best indication of temp inside the transmission.   From there it is back to the pain of running that sender wire to the cabin, I've run it up near the passenger headlight, into the battery box, across the channel at the back and into the master cylinder area where I ran out of wire length (and patience). Remainder of the job is through the grommet near the accelerator pedal that I've used previously, then across under the dash to where I will temporarily mount it on the console for track days (and remove it other times). The gauge will also need IGN, BAT and earth (I'm not going to worry about illumination as I'll unhook it between track days)
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
