settle down woman!!!! your suposed to be cheering on the aussies!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
dave
Me calm down there is no such thing :)
I am....................!!! But with your no show on the weekend Lofty I am a little upset! :D
  • Replies 1.4k
Posted Images
Aww you picking on my Starter Andrew!!! Them fighting words you know lol I was in Race Control..we dont muck around at the state champs :D
hope you can make it to wakie on the 24th april for MRA Round 2!!!
Do you need marshals Jess?
I'll brave the cold and come help if you need it....might make a weekend out of it cause im helping Disco stu on the sunday i think
pretty sure I will need Marshals and always appreciate your help!!!! ;)
I will be in town Friday night getting on it ;) so if you need accomadation let me know..will try and organise a room for you at the onsite cabins !!!!
P.s will stop hijacking the superlap thread now for my events..Pm me if you want any more info!!!
Only "rear engines 6 cylinder cars" are excluded from the event, so to that read 911's.
So Moslers/Lambos/and all the rest of the GT stuff are elligible as far as I know.
Its No rear engine 6 Cylinder or above vehicles allowed, so rules out all of the above i thought?
Not sure how the Honda NSX is allowed to run? well it is a Mid engine car so maybe thats the loop hole?
OMG the event is going to be off the chain! I attended a meeting today and it's all going extremely well!!!!
So cant wait...soooooooooooooooooo excited going to be very special! :)
Is SAU putting on a car club display at the Show n Shine???
Ohhhhh...Well I met the guy that is handeling the show and shine..He has just gotten back from Japan!
Will pass on that SAU wants to do a display!
id love to display my car at show n shine if youll have me. ill be there for the event anyway
we probably would if Ian would return Neil's call :)
Thats a bit odd..I actaully asked Ian and he said he spoke to someone from SAU about the show n shine already..
Show n Shine Link...Click on me!!!!
Steve is the man to talk to and I will make sure SAU is looked after if you guys are really interested in doing a display!
I know I would like to see it...
Awesome Sean...Thats the sort of enthusiam I love to see!! Click on the link my friend!! :(
Hey mate, they're all mid engined so qualify. It's really only specific to 911's... and beetles :(
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
    • And now the bloody flapper is jammed slightly open. Lazy as all f**k in 3rd-5th (very hard to convince it to make much boost before you run out of revs), but will make 12 psi in 1st, which shouldb't be possible with a 5 psi spring and controller set to <10 psi. Methinks I'm lucky it jammed where it did, rather than fully closed. It's actually a well weird situation. Careful examination of what's happening in the back of that housing when the gearbox comes out and all the other stuff (injectors, AFM retune) is supposed to be done, next week.
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
