  • Replies 1.4k
Posted Images
OK, i just can let this go.... so what is the story behind this pretty serious looking piece of kit?
Thanks to MaTBoY from photography section od SAU
Is it possibly the old Performance Metalcraft R33, that used to be yellow and have signage of som evineyard...just with a colour change??!! WOnder what happened to that car, it an twin 2835s or something and had plenty of kit
its a custom built RB32 from signature performance in Ipswich, Mick built it and drives it and has had it for the 3 or 4 years i have known him. Noel knows more about power figues and the like but it is very impressive. He had a lot of trouble getting the power down
Not sure what boost/power he was running at superlap but it has made 650rwhp on 21psi but around QR he only runs alot less boost due to wheelspin (which I believe is around 400-450rwhp).
I'll tell him about this thread this afternoon as he's tuning my car atm.
Its a work in progress. Mik had this car running some quite handy times at time attack.
An 11th hour decision to upgrade for super lap saw about 2 months of the most intense upgrades you could imagine.
Home made carbon fibre doors bonnet etc, Dog box, chromolloy cage, weight reduction and so much more.
Unfortunately time was against them and the car lacked development time to get the handling side properly sorted.
It augers well for next year however with all the hardware in place and a superlap visit under the belt I think you can expect much bigger and better things from this team next year.
anyone notice all the steam inside the r34 in the photo on the last page! hahaha
and water coming out the sill
Have a look just ahead of the right rear wheel in this photo ...
http://sphotos.ak.fbcdn.net/hphotos-ak-snc...7_4491309_n.jpg
- The Tuners Group
Edited by TheTunersGroup
Vid for those interested.....yes it is a Civic :ermm:
Fastest NA Open
Fastest FWD Open and Outright
8th Outright Open
Time 1.40.94
http://www.youtube.com/watch?v=0dnQW9MT-no
It was quick boz but i never thought I would hate the sound I hated worse than a drag rotor until i heard that f**ken noisy pos. :)
hey guys.... ive been up all night tossing and turning and thinking about next years superlap.. and my car....
why are there so many rules for Open... but Pro is invite only??
i want to move my engine back 15cm and section out the firewall... but this is not allowed in Open as the factory firewall must remain?? is that right??
but i cannot enter into Pro on my own accord as its invite only and spots are limited... is that right??
what can i do?? who can i talk to??
do i just do it and run some quick times at track days and hope for an invite??
pro just says no tube frame chassis or tube frame extensions on the chassis.... doesnt say
moving the engines around is allowed in japanese time attack..
i dont want a sports sedan category either... 15cm is hardly making it a sports sedan.. the original dash and everything will remain.. the firewall will just be sectioned back to the windscreen level..
if the original firewall must remain does that mean i cant section out bits to allow a pedal box to be mounted as far forward as possible??
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
