Considering the problems that the evo and the 34 had, I don't think the first day counted much dialling happens on the first day, add to that the large drops in temperature over the day and the changes to track and tyre temps from midday to 4pm and only 15 min sessions, I think they would love more track time to work on things.. Specially when you are aiming for one lap... You don't have the comfort of having 40 laps to get adjusted and make ip time.
  • Replies 1.4k
Posted Images
russ has a good handle on the brakes now and a few tips learnt on trying to eliminate the pad knock off problems that GTRs with big brakes are notorious for.
There is a fix for that, we used to have the same problems as everyone, but changed the front wheel bearings to a ball type bearing (tapered std) and the problem is fixed. have had same front bearings with no knock off for years now.
dave :)
ps The BSM GTR is for sale too.
Edited by lofty
dont kid yourself, it is expensive to participate let alone be competative.
i hope to have the car sorted for this next year, just dont know whether ill need to run the big engine. hopefully i wont embaress myself.
Its made me realise how much money I will need to spend to make my car even remotely close to the front runners :)
That's probably right.. I thought it was $800 entry though... The tyres would be the killers there... Specially if your running 265s on 18s.. 2k wouldn't even get you 2 fresh sets.
2k won't even get you the first set! not of anything competitive anyway.
$2K will just get me one set of 285xR18 RE55's
I want to know where you get your tires !!
would any regular creekers like to take a guess at the crowd numbers. Saturday appeared to be fairly well atended.
no idea...except to say its the biggest crowd I've seen there which is great
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
