  • Replies 1.4k
Posted Images
isn't that Friday the 21st? competition Saturday 22nd?
Now im confused - from the assigned 5 sessions - surely a couple of these would be practice and surely on the Fri? or maybe 1 session per day?
http://www.superlap.com.au/2009/?p=2278
Edited by HKS26T
Thanks for that Steve. Pity there isn't one closer though, was really hoping for an open day on the 19th/20th.
Harry: I think both days are competition mate. I was hoping to get a good day in prior.
Some bling bits just arrived for The SLot Car.
We discovered this billet alloy dry sump set up made in USA for our VQ30 twin turbo motor we are fitting. It is a girdle, sump, oil air separator, dry sump pump and oil filter bracket all in one. THe motor will be more reliable, help piston rings seal better, less drag for crank, both indirectly making more free power. so more power, less weight in front, as oil tank will go in left rear of the car. Also allows us to move the engine further back and lower, lowering the weight in the car, allows us to raise the steering rack to get rid of bump steer, rather than spacing the outer steering pivot point down. It also allows us to run a better front air dam in under tray, as has more clearance.
The new motor should have us well under 1150kg and much better balance front to rear and left to right as mounting the oil tank left rear allowing us to remove 10kg of lead.
Cosworth Plenum on way.
6Boost making exhaust manifolds and GCG supplying turbo's.
wow sub 1150kg sure is light! :P
When we do carbon fibre tailgate with Perspex window and carbon front bar, it will be well under 1100kg. Then have plans for building a 3.8 litre VQ with VQ35 crank and Darton Sleave kit, which we have, and will be easy 500plus rwkw, maybe for next year. Also have plans for custom Chrome Molly front suspension, getting rid of the heavy king pin and upright, this should save many kilos off the front suspension, through in traction control and looking at Ikea Sequential shift kit with ignition kill and we might only be a mile away from the big guns rather than miles.
There is a ARDC supersprint the weekend before on the 16th is a round of the CAMS Supersprint Championship, would be hard to enter unless you are registered in the Supersprint championship as you get first preference, but worth a shot. I will be running the Mazda R100. When i get entry forms will let people know and then you could contact the ARDC.
Thanks for that mate, would really appreciate it.
John: Z sounds like it's coming along nicely, should be even more of a weapon soon.
So I hear on the grapevine that the Scion is coming from the States!
It's apparently now up to 1200hp and has undergone a 4WD conversion with a custom billet alloy cased gearbox! I also hear he's flying the thing over! haha
I think the entry list is nearing 10 internationals, which would be awesome!
I was giving some private tuition to a couple of guys yesterday at the creek who are both running in clubsprint. Far out, there are some fast cars around. R33 GTR in clubsprint spec doing a 45.4 on a hot day is not mucking around. Also good to see Lofty out there with the BSM R32 GTR doing some serious testing. They were pulling 280kph down the chute and were well below the 40 sec bracket :D
Alright whos the one spreading rumours a Viper and Mustang are coming over aswell from the states???
Not happy...got all excited only to bfind out its not true! :cool::cool::D
P.s should get Tacker to come over! :/
    • C'mon! At least come kicking and screaming into the 2000s. BA XR8 bulge.
    • No such thing as E30 in Sydney servos As stated above, flex fuel is your only viable,  and "safe" option I believe
    • VN Group A bonnet buldge 🤣🤣🤣🤣🤣
    • We've updated lots of Nismo items and accessories recently! Nismo in Japan don't keep a lot of stock on hand and they sell out frequently, but they do restock frequently as well. So if you put items in your shopping cart and make payment there might be a slight delay (2 - 4 days), or on rare occasions it might take longer. At any rate if you see something that is not available, wait a few days and then try again as it will likely be back in stock. We are considering just making everything available on the website and updating each order as needed if users aren't to concerned about putting an order in for something that could be delayed. https://www.oemsoko.co.jp/collections/nismo Nismo BNR34 GT-R and R34 (2 door, manual trans) floor mats:  https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r34-bnr34 Nismo BNR33 GT-R and R33 (2 door, manual trans) and Stagea 260RS floor mats:  https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34 Nismo BNR32 GT-R and R32 (2 door, manual trans) floor mats:  https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r32-bnr32
    • AA100 and AA110 are supposedly not cross listed, not sure what the differences are. Most likely you're better off rebuilding what you have unless the housing is trashed by debris circulating in the system or significant amounts of cavitation.
