  • Replies 1.4k
Posted Images
Brighty...Hope your not worried :)
Will definately be a contender with the time you put down last week! :O
Your car is a weapon! plus "Bozlap" isnt at his hometown this time (Oran Park)................. :(
LMAO Love ya Jess :rant:
I have not been driving at Eastern Creek for very long at all. I remember winning some IPRA National title in.....um....1994 haha
Oh John, you poor guy in your underpowered GTR haha at least you have AWD. Sounds like you best read the rules hahaha
You crack me up Benny. Would be fun though :D
All good publicity for the S2000 :O
I know bugger all about the rules but i am thinking the same as you.
Is this John Bostons car or is he a hired gun. 550rw hp in something that light spells too chicken shit to go and mix it where the car really belongs belongs to me.
HAHAHAHA what a crack up!!! 1300kgs light? I know of some GTR's that are lighter.
So you will obviously be out at Superlap wearing your Honda shirt then :(
So you will obviously be out at Superlap wearing your Honda shirt then :P
UHHMM, No, Why would you assume something as ridiculous as that. (Add dancing mango emoticon as the banana was taken)
Sorry, I obviously misinterpreted what you were trying to say. From your lovely literature to your knowledge on the rules, it sounded as though you were a massive Honda fan Noel :P
s'all good Boz, Yes i will be at superlap cheerin all the sau crowd on.
I was hoping to run my gtst but time and circumstance conspired against me as usual.
Might wear a honda shirt just to spite you now. :P
Hi All,
I am running my 32 gtr in club sprint I was gutted last night to find out I can't run toyo 888s, so now I need a different tyre that meets the "street spec" rating ie rating over 100 any ideas?
I've used the federal 595 rs to run sub 60 seconds on the qr sprint track mate. good durable tyre too.
A couple of friends are using the khumo ku36 and it too seems like a good grippy tyre, They get no where near the mileage that i get from the feddy's but they are a fair bit cheaper to buy so i guess it all evens out in the end.
I'm staying away from the Rsr given I recently had an issue with them
Hi All,
im running Ku36's in clubsprint....what problems you have with the RSR's
Hey someone has to do it...so hats off to the guy building a car to best expolit the rules!! Sux to be Russ in a GTSt, but with RB20 goodness behind him he is still a winner...until he chucks an RB25 in it then he is just anothe kiddy fiddler! :P
Just saw this. Don't worry Bris. Power upgrades won't be for a while yet haha.
Yes I will be slaughtered down the straights but I'll just try and piss em all off in the corners...
Best thing about the 180km/h speed limiter my car had everytime i was at EC is that i could look people in the eye and say i didnt brake for turn 1 and was flat through turn 1 :) It was good as i never had to worry about braking etc, i could just concentrate on the right line and means i was usually pretty quick through there....lol but slow down the straight :D
If you can man up through turn 1 you will round up most of the softies who drove away from you on the straight by turn 2. You'll have them at turn 2 if you can do some really late braking :down:
Keep the advise coming... :P
Thats all i've got. It was the 1 place i could catch and pass people when i was there last in my NA s13. I spent the rest of my 1:54.5 thinking how i could use some more power as i'd gain on people due to higher corner speed and at the first small straight they'd get it back.
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
