  • Replies 1.4k
Posted Images
Next out again at 4:30 Roy. Patience my friend :)
Lets hope all the cars having troubles can all get out there and just eek a bit more out of their cars!
And I just heard all I needed to :) Russ Jr (calling his Russ Jr as I just realised we have two Russ's driving black R32s, so Jr GTSt, Sr GTR :) ) has just pumped out a low 1:47s in his second last session! :) GO you good thing, get that std RB20 with a 2530 and about 220rwkws with off the shelf used Teins from Japan into the 46s!!!!! :)
http://www.natsoft.com.au/cgi-bin/results....05/2010.EAST.S2
times up on Natsoft
WD mark & crew gr8 effort guys.
Who is the nutter in the 200SX that took it to the EVOs and R35 in Clubsprint! Amazing effort.
All in all great effort and great times by the whole field it seems. Commiserations to those that have bent/broken things. Hats off to the Int'l guys, I am surprised therefore mega impressed by the speed of the cars! :)
And before you take a shot Neil, no, they dont have to impress me, or should care what I think. I am just pointing out that I wasnt giving them enough credit with regards to how quick there were going to be!
its all to early to make and bold statements but i was sure the tomei cusco WRX would bounce off the track being how rigid it is. it has really surprised me how well i†s gone.
also surprised to see the serea x2 car not miles ahead.
epic day!!!!
what happened with the pan speed and Berry's 34 at turn 4?
looked like berry was on a cooling lap and they got caught up cauing the pan speed off into the grass! looked interesting!!!
caught up with alot SAUers today which was good
Troy - you talking about Jacky Yick? yeah top steerer! IPRA u2L champion a few times IIRC?
Jacky Yick must be top steerer and must have a decent car under him to humble all the lunar space modules around him.!
hehe, i am kind of happy inside that a 2L rwd car on street tyres took it to the field of what i was expecting to be the R35 one make series with the Evos behind! What is hilarious is he would have been about 6-8 sec a lap quicker then me on the same tyres...FARK!
yep... i was sitting right next to you guys on a picnic blanket, until there was movement, then i ran down to the fence.... heck, i even came and asked you's about the barbecue tomoz to make sure i had sorted somewhere dry to be in the morning :) haha... spose i should have introduced maself... but thats just lame...
Oh hahaha you're that guy!
When you left I said to Doof "who was that?" he said "I don't know, I thought you knew him" then an awkward silence for a sec hahahahaha
wow... 2 full days of old mate in the tower speakin shit has really taken its toll on my head. Just when i thought I CANT TAKE IT ANYMORE!... he stops. Ah the serenity.
Someone needs to tell him it's ok to be quiet sometimes.
Did the guys in the last clubsprint group get to go back out after the Evo crash?
Was a shame Brian didn't didn't get back out there.
And that commentator was a twat. It was nice when his batteries went flat.
    • Sorry I was being harsh there, but am I wrong? You can buy a M340i easily, and there's loads available second hand. A lot more workshops modifying them as well. How about getting parts for them? Don't get me wrong, I'd love a 400R, even a 4cyl (I looked at a few V36s before buying my shitbox BMW). Sadly Infiniti died in Aus and we're stuck with importing them as niche vehicles. Supply and demand
    • Probably straight swap for an R32 GT-R? lol
    • Yes I think we changed out the transmission fluid as I had a leak last year so we changed out the seals also. Need to check.    I should have said just change from 5th to 4th gear … down shift. There’s a grind.    I have a new clutch X clutch … but as I said all the changes in other gears are fine.
    • Change the transmission fluid. I would try Motorcraft XT-M5-QS if you have it in your area for a reasonable price. Also, double check your clutch is fully disengaging. If you are not pushing the clutch pedal to the floor fully for every shift now is the time to start. Make sure the clutch is fully bled. The damper line requires two distinct bleed points to be purged of air or it will not disengage the clutch properly. If either hydraulic cylinders input or output are losing hydraulic pressure in their seals/leaking you can have problems like this. If you've ruled out everything else then the most likely explanation is the synchros are worn and you need to double clutch the shift or rebuild/replace the transmission. The transfer case is discontinued FYI so you may want to rebuild it while you're in there too. If the chain stretches past spec it can do a ton of damage.
    • You're selling the SS?! How much are you asking on it?
