i just put an rb25neo from a stagea into my r32 gts-4. i cant get it started and i think this might be my problem:
i have this part of the loom which isnt connected to anything atm. i dont know where it goes? and what its for:
there are two plugs on the this loom which plug into the main loom under the intake manifold:
and here are close up pics of the other plugs/parts of the loom
thanks
https://www.sau.com.au/forums/topic/296253-what-part-of-my-loom-is-this/
just had a look on mine . is your motor 2wd? has the traction controll motor on the throttle body ? it might be for that ? the grey plug looks like it would go on the plug to the tps on my engine . in the same place and same type plug . mine tps had 2 plugs grey and brown . the grey one in my car is blocked off from the factory tho
its a 4wd motor. and it doesnt have a traction control motor.
what is the alloy thing ? does it have a part number for anyone to fast ? almost looks like it could be gear indicator for the auto or something
i dont know what it is. it says "Niles Japan 4A02" on it.
i was having a look at mine while i had it apart today, and i could find anything that looked like that. the 2 plugs together, the brown and grey one, go straight back into the loom and i cant follow it without cutting the loom apart. as lachlan has said, if you can get a part number off one of the bits we could run it through fast to get an idea of what it is.
edit: a nissan p/n will be something like 23470-0V300 for example
Edited by QWK32
First pic' looks like the gear selector from an auto... and the brown connector is the one on mine (auto) which gets pulled to keep the auto box in 3rd (limp mode) when it gets dyno'd. If it's an auto loom then there'll be a 'detent' (park/neutral) switch somewhere which needs to be shorted to get the car to start (safety feature on autos). Somewhere in that loom...
Mine's a 4WD auto stagea and it has all 3 of those plugs, one above the other.
Edited by DaveB
If you are using the Stagea ecu (in order to run the vct) then Dave could be right but you will not have the socket to put the plug in and short out. However you must have done a major wiring job already as the Stagea ecu wouldn't have fitted the R32 ecu plug. What ecu are you using?
what does the safety switch do?
does it stop the starter motor from working? because my starter motor turns the engine over and im getting spark and fuel.
does it stop the car from starting another way?
thanks
im using the auto stagea ecu.
i dont understand what socket you are talking about? is it on the stagea loom or is it supposed to be on the car?
and where is it located?
thanks
thanks
On the Stagea there are three sockets just by the battery which relate to the auto. These must be wired back to the ecu (the auto ecu is inside the main ecu) through the loom. There is a smaller loom that loooks a bit like one of yours that goes back to the auto trans and has plugs which go into the sockets by the battery. One of these (I'll try to have a look in the morning which one it is) is for the circuit that makes it impossible to start when the auto is in gear and when you convert to manual you have to short this socket out. There may be a Stagea owner near you who could show you what they look like. Of course you could try to do this at the ecu but I can't tell from the pinouts i have which one you need.
i thought that if the car wasn't in park or neutral it wouldn't crank at all? cant say i've tried it lol. but because he has it cranking and even firing the injectors and coils, that could mean that its not the park/neutral inhibitor switch.
stepping away from the loom, have you done all the other checks, fuel pump priming, fuel lines on the right way, coilpacks plugged in in order. who did the wiring on your car? even though you have power on the ecu, did you hook up the ecu start signal when you where wiring it? its a signal so the ecus know when you are cranking and trying to start the engine?
Edited by QWK32
For some reason Ive got a feeling it could be CAS related... Different series 25's have had diff CAS's and made other cars not star but they would spark and turn over ect...
hey mate.
it might be the problem. where did you hear about this?
is there a thread on it? i did a search but i couldnt find anything
i purchased the cas off ebay. it was off an r34 rb25neo.
thanks
yeh i dont think its the inhibitor switch.
the the engine is getting fuel. and fuel lines are ok. and the coilpacks are in the right order
me and a friend did the wiring using this guide.
http://www.skylinesaustralia.com/forums/R3...=body+loom+plug
what is the A/T mode switch signal (POWER)? because i didnt wire that in. i didnt think i need it
would it need ignition supply?
no i didnt wire in the ecu start signal. the guide didnt say it was needed
when you say ecu start signal are you referring to the Ignition Switch (START) signal?
because i cant find ecu start signal on the pinout.
yeah thats what i mean, Ignition Switch Start Signal.
With the CAS, what type of CAS did you end up getting, is it a black plastic case Hitachi one? because thats the one needed for the RB25 Neo. not the silver metal cased mitsubishi one.
Edited by QWK32
    • it was good to see our presence at GTR festival..hope to see more SAU at these events
    • This is awesome.
    • Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle.. Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well. Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees. We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour. Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car. I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
    • What transmission are you running?  It's a bit tricky with the scaling, but at face value the power "curve" looks more like a "line" which is a bit odd... basically a lot more like a dyno plot I'd expect with a highish (compared to a factory auto) stall torque converter type setup. If this is running an auto then this kind of boost control challenge is definitely a thing, the rpm scale on the dyno doesn't reflect what the engine is actually doing (unless the dyno has access to the engine's ACTUAL speed electronically) and what you'll get is a big rpm flare up as the engine torque launches past the converter pump's ability to resist torque at that rpm, then as the converter starts picking up rpm it will kinda even out again and the engine rpm will pick up more steadily. The trick with this "flare up" is if it's kinda near the boost threshold for the turbo then the engine's airflow requirements to maintain the previous boost level will outrun the turbo's ability to supply that boost - so you end up with a natural flattening off, if not dip when that happens.   If you are running closed loop, or even tune the "feed forward" wastegate duty cycle to deal with that rpm spike then when the engine starts settling to a more typical climb you'll actually have a situation where the gate is "too closed" and boost will run away for a bit, then have to pull down again.      It's not trivial to get this perfect as most boost control systems are generally expecting more predictable engine rpm rates of change, but if you *know* that's whats going on then you can at least "accept your fate" and realise getting that area perfect is kinda chasing your tail a bit, and assume that if the rest is working sensibly and the spike/dip isn't completely uncontrolled then you should be good. Sorry if I've gone off on a tangent, but the dyno plot and boost control behaviour look a LOT like what I've seen tuning autos in the past. What ECU are you running? Could possibly be convinced into looking at logs if I get too bored this weekend haha.
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
