Asking Price: $19,900
Odometer: 139,XXX km (engine has done less)
Colour: White
ENGINE MODIFICATIONS:
GT30 turbo with 0.82 rear housing (full boost of 17+ psi at 3300rpm)
High-mount stainless exhaust manifold
Blitz blow-off valve
Bosch Z32 AFM
Ross Tuff Bond harmonic balancer
Adjustable exhaust cam gear
Apexi Power FC with Commander hand controller
3.5 inch Apexi N1 (quiet) exhaust system
3 inch custom stainless dump pipe
Remote oil filter locator & oil cooler
4 inch stainless intake pipe to turbo
Long nose K&N pod filter in custom aluminium airbox
Splitfire coils
Sard Fuel intank fuel pump
Nismo 740cc injectors
Nismo adjustable fuel pressure regulator
50mm waste gate with stainless screamer
Greddy Profec B spec II boost controller
Greddy radiator cap
Performanz front mount intercooler + stainless piping
Custom oil breather tank
DRIVELINE & SUSPENSION:
OS Giken twin Plate clutch with lightened flywheel (20,000km old)
RSR springs & KYB shocks (lowered)
Tomei Hicas cancel kit
Adjustable rear upper control arms (rose jointed)
Nismo rear sway bar
Adjustable front strut brace
Camber bolts in front
Rear cradle pineapples set for traction
Redline gearbox oil
WHEELS:
17x8 & 17x9 Zelda Tri-spoke Jap rims (dished)
Tyres - front 235's and rear 255's
Front tyres will require replacing soon, but rears are near new, with 2 more new rear tyres supplied
INTERIOR:
Very clean series II interior
Genuine Nissan carpet mats
Nismo leather gear knob
New leather handbrake and gear boots
Resprayed dash in silver
Custom mounted gauges
SOUND SYSTEM:
Alpine 9886 (2008 model) cd/mp3 player
Fully USB and Ipod ready
Alpine type R front splits (120rms)
Alpine type S 12 inch sub in carpeted box
Full sound-deadening of doors
EXTERIOR:
Full M-spec body kit inc pods and skirts
Series II front bumper with lip
Stealth boot lip
Clear side indicators
I have owned this car for just over a year and have loved every moment of it. It is in beautiful condition inside, outside and under the hood, and my pulse still races whenever I get behind the wheel. The engine has been conservatively tuned and has plenty more potential. Reluctantly, it's time to let it go for financial reasons. I have to note that the heater core sprung a leak so I have bypassed it within the engine bay for now.
I have advertised on carsales.com.au but thought I'd post here too, as I'd much prefer the vehicle to go to someone who really appreciates it.
My contact details for anyone interested:
Email: [email protected]
Mobile: 0402404192
Is there actually anyone in Perth active and interested at all?
This car has had over $30k worth of work performed on it to an excellent standard and would save anyone a lot of money in mods in the long run.
  • 5 years later...
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
