i have a 3071 turbo that had been sitting in my garage. i sent it to gcg to get a rear housing put on as the current one developed a slight crack. the problem is that i'v been given a quote for close to 1300, does this sound normal or am i being overcharged because i can buy a new turbo for not much more.
https://www.sau.com.au/forums/topic/296284-3071-rear-housing/
you can grab a new rear housing, .73 size, from AVO turbo world, for $700
http://www.avoturboworld.com/content/view/49/26/
thats what is on the rear of my 3076 :sick:
Tangles
did you manage to get any power out of yours
I ended up pulling mine off and going to the .82 external gate because it didnt want to make power for me
Mine also had hairline cracks around the wastegate hole but GCG told me that's normal
its just sitting here in the carport so if you wanna buy one down the track let me know
Edited by Haines
Tangles
heya
ATS adelaide turbo services suggest the combo should be good for 280rwkw give or take
that'd be on a manual rwd rb25det : auto awd would lose 20kw
with auto, mine is flowing 240rwkw nice and clean, with heaps more power in it - 260wkw auto awd is the goal
fixed the issue of my fuel cut to an extent - 6500rpm is now the gear change point aka limiter; unfortunately that leaves the 3076 in the meat of its power delivery
on the dyno at 6500 the graph-curve shows it'd hit 250rwkw at 7000rpm
but then again, auto full boost quick-changing at 6500rpm right in the meat of power delivery isnt that bad. also depends on boost level/settings
got a power run on sunday 8th dec on a all-wheel drive dyno, so will see how it goes on full boost
will update the auto performance thread accordingly.
:sick:
If you can send in the CHRA we can profile a .82 internally gated rear housing to suit it that bolt on to your stock manifold and dump for $500. This housing is capable of holding 22psi of boost on internal gate.
    • I’m guess it’ll end up with a turbo
    • To install new hicas ball joints do i really need to pay for the Frenchys hicas install tool? Or can i use something like this? https://www.ebay.co.uk/itm/395524214497?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D281023%2C280568%2C280618%26meid%3D4018390c9ba246f794ed58b8b19ec80a%26pid%3D101430%26rk%3D4%26rkt%3D12%26sd%3D205160403603%26itm%3D395524214497%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DCompVIDesktopATF2V2AndXaiHotClickWithCompV6WithEbertNRTRecall%26brand%3DUnbranded&_trksid=p2332490.c101430.m2460&itmprp=cksum%3A3955242144974018390c9ba246f794ed58b8b19ec80a|enc%3AAQAKAAABMDJfxvEKz%2FWsdyy97PIVwAhtkTIJPGKp%2Bu7TYjjsvNO4eN9duTRR%2FSVFYts6UXmN8tSK75ee0LypjLaKkPNQ2gkat4DyNLnViXKBVpI1%2B5fAYfWiGJa5QlqEPseqbSJUD9gVo2KSXbnmQjuPDJH4flTH2bOLSO%2FvMrLjgPDIc7vGrlKtoSauZb0q%2Fu43zLR0J8tg1z5dPMV%2FcHtnqRYXb7R7V8G%2FrQGhpY1sWtGJXc4TWc78ccs69UXnMiCqqd05ITd%2BY7Vwbq5Uzd%2FWhmiZCytO66vqDnbJn03qN%2Bin0ImF5sgbgu9uD45tXNN8cr4IWfqzIEEpaKcgqilwbTDxMkIQ4sGcgz7IhYONV017vE6P9ksZ7n%2FFVwgs3kAfMb0%2FLGjwaqhwo0yilTIjGHg9mwU%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01JMR0X9WMB8DPEX82P2P3CRXN
    • I would be lying if I said I wasn't interested in what MCM were going to do with the NC I really enjoy their banter and occasional collaborations (like Alan from TSF, Ben from BCW, or any of the Haltech guys throwing around their experience), and I have probably watched everything they have put out
    • Not yet, we basically drove it to a private road, got the logs and drove it straight back. I think I need a new passenger seat belt after the mrs squeezed the life out of it.
    • Sounds insane! 🤤🤤🤤  Do you have any vids of it driving?  A flyby would be nice!
