Hey guys only about 2 weeks ago my car was running fine but the last week when ever i start my car it sounds like a rotory as a first start it then it blips on idle like i have a massive f**k off cam in it , and every time it pulses it blows black smoke out the exhaust , and i mean REALLY black! sometimes it covers the whole front yard it black smog ! .. it continues to do this for around 5 mins then it goes away sough of , until you rev the car and it starts all over again .. does it worse when cold but does it all the time when its warm , i've pulled off AAC and cleaned it , Cleaned AFM and tryed injector cleaner + new fuel filter and just about ready to push my car off the cliff im sick of it . I'm really starting to hate my skyline because of this isse! can somebody please help me?
ANyone with PFC Please Post ur INJ Map for ur 20x20 on ur PFC so i can roughly see ur injector settings and also im running 20 timing it looks like on pfc but my timing reading is false i think
https://www.sau.com.au/forums/topic/296337-erratic-idle-black-smoke/
its nothing to do with the PFC. as the previous guy said check the basics and intercooler pipes
its likely a joiner has come loose or a pipe has come apart or joiner split
failing that, to prove the PFC isnt at fault, get a stock ECU and plug it in, youll likely have the same issue is the PFC isn't at fault
maybe not....
I will PM you some instructions to try gL3nJaMiN88
i doubt its my intercooler piping leaking ? i'm pulling 17psi and it boost's fine and holds boost to around 15 to redline .. so yeh ill have a look at it , i did change nearly all the silicone except the throttle body one . its a weird size? does anyone know if its 2.75 to 3.00" ??
i'm pretty sure it doesnt have anything to do with my AFM .. I'm running a Z32 and it was set up by the tuner? it is set at VG30 AFM and when you go into it the number 1. Is highlighted in black .
I just figured out how to fix my problem totally , but it's only a bandaid fix. I went into settings and then when to IGN/INJ and i went to where it says " INJ CORRECTION" now while the car is on red i set the setting from "1.00" to "0.800" and then start the car , It starts like a brand new skyling and idles perfect and does not spit out black smoke what so ever .. and once the car has been idling for a while i set it back upto "1.00" and it still idles good .
When i start the car WITHOUT the bandaid approach it does the blurp blurp fluctating between 300rpm to 1500rpm in short quick bursts and blow's black smoke everywhere and it deffinatly smells like unburn fuel and it turns my rear bar into an ash try!
Somebody please help me ?
Anyone running :
GT30/71R
Sard FPR @ 42PSI on idle
Walrbo Fuel Pump
High flow injectors around 500cc i think ( mine is set at 95% Duty in injector)
Please post ur INJ Mapping from ur Power FC .. Also ur INJECTION section and Water Temp Adjustments .. It might help me ( Im not going to modify settings i just wanna see what you guys have )
Any help on this issue will be much appriated .. I have just spent big money on tune and tuner does not wanna even look at it , so im pretty much only depending on you guys to help me
what do you mean number 1 is selected? the first afm is stocker 33, z32 is the 3rd one, altho if you had those mixed up it would make the car run lean, not rich.
if your injectors are 500cc and your correction is at 95% then thats a problem. correction needs to be figured out by diving the standard size by the new size. 370/500 = .74 or 74% which would be almost exactly what you ended up with when you set the temporary correction to .800. to have a correction of 95% your injectors would have to be flowing 390cc. if yours are bigger than this then take your car back to whoever set it up like that and get them to fix it.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
