im after a good install for a decent price in the Sydney area, anyone reputable around or should i just head down to strathfield audio ect.?
I wouldnt but maybe Chris Rodgers on here or one of the local Sydney people can enlighten you to a better place to go ?
Jim from Sideshow Performance wiring did an awesome job on my old R33.. bit pricey but worth every cent. Had two break-in and i've still had the car.. only had to replace busted ignition barrel.
http://www.sideshowsperformancewiring.com....hp?categoryid=8
Also heard good things about Platinum Car audio.
Cheers,
Johno
first choice - FHRX ( http://www.fhrxstudios.com/ )
second choice - Doran ( http://www.doranproaudio.com.au/home/default.asp )
FHRX is a little pricey, but do quality work
i wouldn't let Strathfield touch anything i owned with a 10 foot pole
EDIT - what car, and what do you need installed?
Edited by Stooge007
LOL I wanted to be more Politically correct but you said it for me mate
sydney - crankin car audio condell park. see hakki mention me.
  • 3 weeks later...
tony,
since you are out west (and I hope you haev not moved.) go see crankin car audio in condell pak. hakki is quite good at what he does and will have no issue doing what you are asking.
Hi Chris,
I've just recently purchased a 2001 stagea and i'm on the northern beaches of sydney. I've got to get an "approved" immobilizer to be insured for theft under justcars.
I've searched around a bit and got all sorts of conflicting opinions.
I think what i should do is get a mongoose m80g, and get someone in to install it..
But with everybody saying they're the best installer and then hearing all these stories of bad installs, i'm really hesitant. Is the mongoose a good option, and do you have any recommendations for install?
Many many thanks.
Andy
autowatch 446 RLI or 446P.
if you want try to hold off till mid Jan as I'm doing a run down that way and I can do it.
let me know as it will take a day to do properly.
nah I'll do that. I'm a dealer for autowatch anyway. thats the good thing about the brand - its a specialist brand that is not available to everyone on the block.
give me a call on monday.
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
    • Wish someone would start a racing series for Group A replica cars, a bit like Touring Car Masters but for 1985 onwards and not grandpa's falcon and/or Monaro. I know they race in some historic class but that's for original cars, no replicas allowed.
