im after a good install for a decent price in the Sydney area, anyone reputable around or should i just head down to strathfield audio ect.?
I wouldnt but maybe Chris Rodgers on here or one of the local Sydney people can enlighten you to a better place to go ?
Jim from Sideshow Performance wiring did an awesome job on my old R33.. bit pricey but worth every cent. Had two break-in and i've still had the car.. only had to replace busted ignition barrel.
http://www.sideshowsperformancewiring.com....hp?categoryid=8
Also heard good things about Platinum Car audio.
Cheers,
Johno
first choice - FHRX ( http://www.fhrxstudios.com/ )
second choice - Doran ( http://www.doranproaudio.com.au/home/default.asp )
FHRX is a little pricey, but do quality work
i wouldn't let Strathfield touch anything i owned with a 10 foot pole
EDIT - what car, and what do you need installed?
Edited by Stooge007
LOL I wanted to be more Politically correct but you said it for me mate
sydney - crankin car audio condell park. see hakki mention me.
  • 3 weeks later...
tony,
since you are out west (and I hope you haev not moved.) go see crankin car audio in condell pak. hakki is quite good at what he does and will have no issue doing what you are asking.
Hi Chris,
I've just recently purchased a 2001 stagea and i'm on the northern beaches of sydney. I've got to get an "approved" immobilizer to be insured for theft under justcars.
I've searched around a bit and got all sorts of conflicting opinions.
I think what i should do is get a mongoose m80g, and get someone in to install it..
But with everybody saying they're the best installer and then hearing all these stories of bad installs, i'm really hesitant. Is the mongoose a good option, and do you have any recommendations for install?
Many many thanks.
Andy
autowatch 446 RLI or 446P.
if you want try to hold off till mid Jan as I'm doing a run down that way and I can do it.
let me know as it will take a day to do properly.
nah I'll do that. I'm a dealer for autowatch anyway. thats the good thing about the brand - its a specialist brand that is not available to everyone on the block.
give me a call on monday.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
