I have had my Nissan Y34 Cedric VIP 300 for a few months now. Got it off Iron Chef.
It looked like this but with stockies on it.
After a few weeks i got it tinited.
Then after waiting a few months for my wheels to arrive they were put on with a slight gaurd roll on the rear and front and it sat like this for a couple of months.
Wheels are 19" Work LS406's with custom Burning Black Painted Centres. Sizes are 19 x 9 + 20 and 19 x 10.5 +20. 245/35/19 and 275/30/19 Sumitomo Z3's
After spending a few weeks trying to work out how to go about the busted Shocks it had i finally manned up and Ordered a set of JIC FLT FAR Coilovers. Had some great help from Importmonster Guys with this. If you need anything for your car hit up www.importmonster.com.au. They will help you out as much as they can and with anything you want from japan. Be it for your car or some random japanese thing. They can pretty much source anything.
Car is now sitting like this all day everyday with no scrapping or hassles at all.
I have put a sub and amp and replaced 6 of the 10 speakers in the car for my enjoyment.
I have plans of getting a kit for it. Just have to save up the money for the kit.
I hope to one day get some engine mods for it. Bigger turbo and injectors, Front Mount and the likes.
But the stock VQ30DET engine has enough balls for cruising around adelaide for now.
Id like to thank Matt and Joe from Wheelworx for helping me get the rims and tyres.And for letting me do it all at work.
Stewie from SFR for helping me put the coilovers in.
Adam from 619 Customs for the sick installs bro and the tint :banana:
I will be out and about in the thing as its my daily. Alot of ppl think it's a new Unrealesed Merc. Alot of ppl just stare trying to work out what it is.
If you want to come down and have a better look Come down to Wheelworx on Port road. Ask for Brenton (me)and I'll answer any questions ya have about it.
K Thanx Bye.
https://www.sau.com.au/forums/topic/296357-y34-cedric-vip-300/
  • 6 months later...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
