HEY GUYS,
im half way threw removing my plenum it seems i need to remove the bottom
vac/idle control unit of the plenum is this correct?? as it doesn t seem to want to come far enough
away from the throttle bodies. has anyone does this or has a step by step??
thanks russell
https://www.sau.com.au/forums/topic/296431-removing-rb26dett-intake/
HEY GUYS,
thanks russell
Do a google search for "R33 engine workshop manual" and download the pdf file.. or send me your email address via pm and I'll send you the extract.
Cheers,
just removed mine...
http://www.skylinesaustralia.com/forums/Ex...tb-t295948.html
remove the fuel filter, wiper water tank, fuel regulator under the plenum, all the vacuum lines, and the hardest part, remove the tube which go between the plenum, the tube for the clutch vacuum and brake...
thanks for your help guys i got it off not too bad took about 2.5-3hrs very tight lol
another quick question i noticed my throttle bodies arn t sealing as i can see light all around
them???? are they meant to seal tight???
thanks for your help :D
    • Welcome Jan, It's very likely that you are in over your head. You'll just have to learn to swim hard and fast! These old rust buckets have more ways to bankrupt us than almost any other car. But hopefully there's nothing wrong that ruins the whole show! We can help a fair bit. There's plenty here who've been fixing these things for >25 years. cheers
    • Hi all. First off, thanks for reading my post. So end of last season I put the car away knowing I was leaking at least two fluids. One of them being rear turbo's oil. I went to my car recently that is waiting in a garage to take a peek with my boroscope to try and see if I can narrow down the souce of oil before taking it out of storage. What I found is not so great I think. The rear turbo is (probably) leaking from the oil drain. The hose and it's clamps are probably the original ones, so most likely just worn out or loose. However I spotted a line of rust going straight down from the turbo oil feed, as if water leaked out of there at some point. Also explains the red liquid that was dripping from my front subframe, which I initially thought was power steering. I can even see coolant drops hanging off the side of the oil pan as well. After a quick hit on the web I found a select few discussions about porous engine blocks. My question is if the pics of the turbo oil feed and the left hand side of the block (imgur link below) looks like it could be exactly that to you. Maybe someone in the community has seen it before and knows what it looks like. If it actually is a porously leaking block, has anyone attempted at fixing it with simple methods like putting a sealer in the cooling system and using something like jb weld on the block surface, or will it just leak in 2 weeks again? I could not find any detailed info or pictures on this topic. If I need a new engine, tell me softly. https://imgur.com/a/knVvmZ8
    • Hey all. I'm 23 and from Germany, September last year I bought a mildly modded 1995 GTR Vspec. Looks great and was fun so far, but I already have a list of issues of various severity that I need to take care of, potentially growing longer the closer I look. I just hope I'm not in over my head, I really want to keep the car and work towards it becoming great. I hope y'all will help me out in getting there, I am positive I will need help sooner rather than later to figure out how to proceed. greetings, some pics of the car I posted to imgur. https://imgur.com/a/StKkabz
    • Would be interesting what the price would be without the barracuda wheels. Looks like he dropped it down to 40k. Maybe his mate wasn't correct about the 50k evaluation. Has always been a dream of mine to own an auto 33. Looks like I'll have to keep saving my pocket money or ask mum for more pocket money.
    • Thinking about importing a stagea as a family car since i’m getting married this year, thoughts? Me and my fiance both like stageas, but don’t have any experience with them
