Advise Needed Please - What Do I Go For?
Hello,
Please be patient cause I don't know too much about all this...
Getting confused between which fuel control to go for.....
Reading up about Power FC's and SAFC and AFC's etc and it's confused the crap out of me...
Which is the best one to go for to suit my RB25DET Neo motor.
Appreciated ;)
hello sandra
please read
"How does the PowerFC compare with the Apexi SAFC, AVCR and other Apexi computers?"
http://paulr33.skylinesaustralia.com/docs/...erfc-faq.htm#18
and
"Apexi SAFC vs Apexi PowerFC, whats the difference?"
http://paulr33.skylinesaustralia.com/docs/...erfc-faq.htm#58
the first section at the top titled unit information has every question you could think of
http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm
PowerFC = full replacement computer
SAFC = p!ggyback computer that works with standard computer
If all you want is to tune your air/fuel ratio to a safe level, the Apexi SAFC will suit your needs...
I'd recommend paying the extra for a full replacement computer, such as a PowerFC ;) It gives much more tuning ability.
As would I :cool:
If I run the Power FC, is the standard computer still plugged in too?
P.S. Don't laugh.....
No Power FC replaces the factory ecu.
If you don't plan on upgrading your turbo or other significant modifications, the SAFC will suit you fine. Tuning is cheap too.
So what runs the gearbox and all the other parts in the car if the standard ECU isn't used?
A manual transmission has no electronic control. AT have there own independant system.
Power FC's are designed for manual transmission cars as there is a bit of trickery involved with the way an AT cars ecu behaves during shifts
The Power FC is a drop in replacement and retains factory functionality.
As other people have mentioned- nistune is a good way to go. Cheaper than power FC and uses the standard ECU with a p1ggyback board (Programmable EEPROM) to change fuel maps and ignition timing.
Beware that when you start considering something like nistune or power fc, tuning is expensive ~$600+
If you plan on keeping your neo relatively stock ~190rwkw go the SAFC, otherwise nistune it
Edited by lukebaldan
Ahhhh k, I see.........
Since mines an auto, what's the best option for me?
I've got a hi-stall too so I don't want it not shift properly.... ;)
Not sure how nistune copes with autos (Someone please confirm)
Definately takes the power fc out of the question
As i said:
-If you plan on keeping your car relatively stock (Boost, exhaust, intake) the SAFC is good cheap upgrade
-If you are chasing more performance (Upgrade turbo, etc.) Then the nistune will give you the best gains and future flexibility
Thanks for telling me about this Nistune....
I guess a lot of peeps have this kind of issue.
All I want is my car to be street reliable, I've
got a bigger turbo, running some boost and a 2.2 hi-stall.....
It goes well now but I guess this is the next/last step.....
Just looking through the forums and it seems a few people with autos have installed nistune with a high degree of success.
I would make 100% that it is safe, you don't want to put unnecessary load on your auto.
The fact that you have a bigger turbo and are planning on a few mods suggests that the nistune option is a winner provided you won't have issues with your auto
Adam, R33 are not compatible with NisTune without going to a Z32 ECU... R34 and R32 are.
Nistune fitted and Tuned at Status is 750 going by what Trent said in a thread, best to call him and confirm, as prices could of changed.
Second hand SAFC 2 is what? 250, + wiring + tuning assuming 500ish for install and tune, then it is easily defected, where a NisTune isn't... Things starting to look a little different now?
SAFC: bends AFR's on a few points.
NisTune: AFR's, timing, limits etc can all be adjusted.
http://www.statustuning.com/
Also I think Chasers, Springy Motors etc do NisTune
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
