Advise Needed Please - What Do I Go For?
Adam, R33 are not compatible with NisTune without going to a Z32 ECU... R34 and R32 are.
Nistune fitted and Tuned at Status is 750 going by what Trent said in a thread, best to call him and confirm, as prices could of changed.
Second hand SAFC 2 is what? 250, + wiring + tuning assuming 500ish for install and tune, then it is easily defected, where a NisTune isn't... Things starting to look a little different now?
SAFC: bends AFR's on a few points.
NisTune: AFR's, timing, limits etc can all be adjusted.
damn..... bloody auto
NisTune should be fine with an Auto as it is a modified standard ECU.
i should finish reading b4 i post my reply lol
ill give it a go, if others are having some luck.....
Yay ok i guess i'll give the nistune a go....
Dez - yes it's finally up and running - could've beat ya hehehe
Still got the Ford beast, I'll run you in that.
Might even put it on display at the show n shine..
Beware that when you start considering something like nistune or power fc, tuning is expensive ~$600+
not really... all depends on how many hours the tuner spends - my Nistune remap by Trent @ Status was $750 all up i'm pretty sure. That's all the soldering, installation, tune, etc. Then i think it's about $80/hr for tuning when you come back with "upgrades" :P not 100% sure..
i would HIGHLY, HIGHLY recommend Trent @ Status Tuning. Nistune or whatever other option you go for. But especially Nistune
not really... all depends on how many hours the tuner spends - my Nistune remap by Trent @ Status was $750 all up i'm pretty sure. That's all the soldering, installation, tune, etc. Then i think it's about $80/hr for tuning when you come back with "upgrades" ;) not 100% sure..
Is Dr. Drift any good?
That's awesome! $750 is a steal for everything + initial tune.
He's tuning my car (nistune) on the 27th so i'll let you know. Some friends I have speak very highly of the tunes he's done on their cars.
Best thing about the nistune is that you can load a standard map into it and it will just run as per the factory computer. I got the ECU done months ago (sent mine to Nistune in SA and they returned it within a few days with the chip fitted and the standard ECU map loaded.. Chip cost $220, fitting cost about $60 plus postage). I've been driving with the standard maps for months now, there's no need to get a tune done until you're ready.
Now in the future if I change AFM's or turbos, my ECU will handle it just fine.
Let me know how it goes.........
+1 nistune I also have a gts-4 (although manual) with a 26 and trent had no problems tuning my car. Advise is to call around though as I believe a lot of workshops are quite booked out atm!
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
