Quite recently i was caught driving on a turbocharged R32 gts-t on my p plates. I got off lucky though because i was only warned and not charged(gave the copper a good story about how i was trying to sell it). So i sold it a week ago for $7000. The same friday, i bought a n/a r32 gts. The car already has a exhaust system but it a cheap buzzy one.
I was wondering what kind of exhaust system would be the best for this car? Im thinking about going to Liverpool Exhasut and tell them to make me a custom one for $1300(thats what i got quoted)... Whats the best size?
also, i want to change the intake system at the same place. Can i put the pod filter outside under the chassis?
how much of a performance boost will i get doing this?
whats the best oil brand to use on a na rb20?
Edited by IM-32-FK
https://www.sau.com.au/forums/topic/296455-what-type-of-exhasut-system-is-best/
2L na, get a 2.25" exhaust the whole way for back pressure, some nice extractors, and a small muffler. As for intake, standard airbox works better than a pod in the engine bay, the cooler the air the better. You wont get any huge increase in power, but it will help the car "breathe" better.
Probs change the oil, change the spark plugs and she will love you for it.
Cannon exhausts are big and hollow mainly used for forced induction cars...
And red P platers that what to be heard. "Look at me, look at me!"
  • 3 months later...
im getting rid of my old stock exhaust on my n/a r32 rb20de and sometime this week ill be putting a 3inch cat back and 3.5inch muff and that should be good. one of my friends has a 180sx n/a with a 4inch cat back the thing still goes better then it did with the stock exhaust,
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
