  • Replies 66
Ok guys, so there has been a fair bit of interest in this thread and a few of you have spoken to me about them (and Scott too I assume)...
.... but Scotty has (finally) decided to make the "Fisher mk2" suction pipe for you guys in and outside of Victoria!
As you can see in this thread, the difference it made to Scotty's car was an additional 22kw at all four wheels (taken from RE Customs dyno) and you can read what difference it made with my car which has no aftermarket ECU or tuning earlier in this thread.
Kits will be as pictured in post#1 and made up off a stock turbo/intake ARX or RS and will include;
Lower half of pipe wrapped in ceramic heat wrap
All Silicone joiners and stainless steel clamps
Barbs in place for BOV return and breather hose
Extension and clamps for BOV pipe
Both turbo and airbox flanges welded onto pipe, ready to bolt up
The only item that you will need is your stock Air Flow Sensor and air flow sensor pipe. You WILL need to cut 25mm from the flange end of the AFS pipe.
The only other thing you will need is time to fit it.
Kits are priced at $450 + shipping
*** Please note that the intake kits will be made up off an M35 with stock turbo and stock airbox/intake, some modification may be required to fit your vehicle ***
Edited by iamhe77
+1 for ARX if its not too hard to fit.
How many hrs u reckon it would take for someone who's got no clue?
My car has stockie exhaust... do u reckon it would make a big difference?
With no modification? Just a case of ripping off the OE intake and installing the Fisher intake?
Maybe an hour or so
Edited by iamhe77
That was a pretty useless question though. As if I'd post asking for help and be ignored. Stagea forum is uber helpful.
yup - its getting to the stage people will start buying stageas BECAUSE of the forum (if that isn't already happening) :laugh:
  • 1 month later...
yup - its getting to the stage people will start buying stageas BECAUSE of the forum (if that isn't already happening) :)
Has anyone been able to install one of these in Qld? would love one but crapping myself at the thought of DIYing it.
The issue is not installing it but making sure it fits your car as its very tight in there as you can imagine.
I can make one and fit it to my car to make sure its ok, then send it up but thats time consuming, and my car is off the road for a day, easier to fit it straight to your car if you werent so far away. Planning a trip south soon? :)
Detailed info to fit it is no problem, easy for a mechanically minded person. Definitely a must do mod if you have highflowed your turbo or plan to.
  • 9 months later...
Sorry to ask a stupid question, but I assume Scotty's car is running aftermarket ECU (haltech piggy or what ever it was?)
If you were running standard ECU, what would the benefit be? extra fuel economy is definitely a bonus! :D
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
