was going to stick a head on this bottom end and put in my track car .... but looking to buy a complete new car
complete bottom end sump to top of pistons $6700 negotiable
has a 33 crank
HKS pistons
tomei rods
n1 oil pump
N1 block 86mm
stock head $1000
will sell bottom end in bits if there is enough interest
text me if your interested
0406945661
photos to come tomorrow
has a 33 crank
HKS pistons
tomei rods
n1 oil pump
N1 block 86mm
stock head $1000
0406945661
Are the above parts new or used? or a bit of both? history please
Cheers
TBB
Cheers
TBB
they are all used, the bottom end hasnt done many ks, still has hone marks.
head is used but needs a clean up
block is 86mm
power fc sold pending payment
Interested in the N1 Block. You say it has few KM. Is that since the rebuild or since new? What's the condition of it. Shipping would be to Canada (T9K 0A4) Payment would be via EMT or Paypal.
got someone interested in the pistons rods and crank - if somebody wants the N1 block
would you sell it to me? i can pick up as im in brisbane.
    • Pinout is different to my knowledge, but you should confirm to be sure. Also you will need to adjust the VQ table in Nistune to suit. I would still recommend sticking with recirculating BOVs, I'm not sure if the R35 card MAF will fully resolve stalling caused by reversion/throttle lift.
    • What issues are those? Previous owner said it wants to stall sometimes. We did test drive and it was nice and smooth so it will be sporadic or idk. And if i just change MAF(the sensor to R35 version) it should be better? And as i asked...is it like "plug n play" with oem MAF from R34?  This is a MAF from R35 right?
    • Even with no BOV you will have issues unless the MAF is a hot film type like the R35 which has some design features to deal with reversion. Hot wire MAFs are very sensitive.
    • So i just change the (whatever is inside ma original MAF and slide the R34 MAF (it is gonna fit right in? ) and somewhere on the hot side a BoV...i presume that would be vented to the atmo? I just "trying" to understand...maybe my mechanic would know this   I would not mind(even prefer) to run stock BoV cuz it is way more than fine but i do not have that and only pipeing what is left is oem J pipe ... I will be running Blitz fmic(to fit oem one side style) and i gonna need custom pipes cuz i do not have rest of those pipes and hoses... But i am want standalone ECU. Only choice i have atm is Nistune...but that is not gonna cut it right?I dont know what Nistune can and cant do... I know you guys know Link and Haltech...but whatabout ECUmaster? I know guys in here run those but i literally do not know about that and do not know differences... Just know to take whatever "my" tuner can work on.
    • Is that the blue one rpm?
