Hi People
A newbie here that has just picked up a R34 GT-T.
I'm looking at up grading the exhaust system. There are a few to choose from but I'm leaning towards the Blitz Nur Spec cat back system.
Just wondering what you guys think and if you have any other tips or suggestions.
By the way I'm not a great fan of the N1 style systems with the angle mounted mufflers - I'm not keen on the look.
https://www.sau.com.au/forums/topic/29653-blitz-nur-spec-for-r34-gt-t/
Hiya mate, I've got a Black GTT with a Blitz Nur Spec exhaust
It sounds great, it's very loud but can get a bit "droney" on long motorway drives. However, let her rip and the sound is awesome. The only thing louder was a 1000bhp HKS Drag exhaust (only 1 very small silencer). I've also noticed that it's got a really small exit when compared to other makes?
Looks like my apexi n1 with not so much angle. I found my exhaust damn loud, it has no resonator at all its all straight through to the muffler. The good thing about these sorts of exhaust is they maximise exhaust gas flow which equates to healthy power gains initially and later on with more mods the drawback is the noise :D I'm glad I dont have a screamer pipe on my external wastegate to go along with the loud exhaust or I'd be cop bait :)
I fitted a 105mm hks titanium drag zorst to mine and cracked 125db when i got epa'd recently.i would suggest going with one thats street legal otherwise you gonna get good at changing your zorst all the time and getting db tests.And angle tip looks MAD!.burnt the shit out of my spoiler tho
Thanks for the input guys.
For a start I didn't realise that the nur spec sat on an angle - I was told that it sat straight (bloody salesman).
A question on db's - is the Nur Spec system with the silencer in place street legal.
What other systems are people running and how do they balance between noise polution and max power gains.
Again thanks for your thoughts.
umm there is a NUR Spec V, NUR Spec R and NUR Spec RR.
Spec R & RR
http://www.blitz.co.jp/products/ex.system/.../nur-series.htm
Spec V
http://www.blitz.co.jp/products/ex.system/...nur-v/nur-v.htm
Silencer won't do you good if you're going to the epa, they won't accept silencers unless they are welded in place :eek:
Exhaust sounds on an RB25DET
NUR Spec
I think the fujitsubo exhausts sound nice but i think theyre abit more expensive than the other brands.
Fujitsubo Super R
Fujitsubo Regalis R
Regalis R
HKS
HIPER
Super Dragger
HKS Hiper
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
