Hi all, I'm selling my beloved GT-R to pay my mortgage ;)
Personal import, I owned this car for 3 years in Japan before importing it on my return. This car was not bought at auction but chosen after looking at a lot of GT-Rs over a 2 month period. I chose this one as it hadn't been fiddled with very much :huh:
I complianced the car Dec 2008, will be sold with RWC and rego.
The car is in excellent condition and drives beautifully. NISMO options include NISMO front bar (standard lip put back on as the NISMO one with undertray was 40mm lower), seats, shift knob, rear wing inserts. Twin pod filters, Blitz intercooler, HKS Electronic boost controller, TIEN adjustable suspension, ENKIE NT03 wheels, 18x11, new KUMHO tyres and Extreme performance clutch.
Small mark on left rear quarter from shipping (Grrrr), will buff out.
Oops, couldn't see how to edit topic.
Price $28,000, currently on carsales.com Car is in Western suburbs of Melbourne.
Contact me, Matt on 0424 183 696 AH only, or email: [email protected]
Thanks @ndrew :wave:
Edited by MattRS2000
  • 4 weeks later...
  • 3 weeks later...
wow, i might be checking this one out its definately what im looking for, but just a quick question you say it has a extreme performance clutch, whats it like? is it ok for traffic driving? only asking as honestly i havnt had much practice in a manual. i havnt driven one in a while and im really missing it.
thanks.
scott.
thanks.
scott.
Thanks for asking SHANE66, can't believe I left that out. The car has done 106,XXX km, 40,000 of those mine with no problems. I'm driving it about once a fortnight so kms creeping up slowly.
The clutch is fine, take up is smooth and progressive once it bedded in, it was tricky for the first 500km or so but it's quite easy to use now.
Cheers
Matt
just got another quick question for you. has it had a major service done with the belts changed? or not yet.
thanks.
scott.
I had a major service with belts including cam belt while doing shakken at 80,000ks. That was about 3 years ago, of course its been serviced as usual since then but the cam belt hasn't been done since.
Matt
  • 1 month later...
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
