it was the first time for me changing the oil since i've owned the car, when taking the old filter out the oil seemed thicker than the HPR-10. So maybe there was an underlying issue with the engine possibly being hidden by the thicker oil?..
The car was warmed for 15 minutes to let the new oil circulate after the oil change, then driven with some spirit with spurts to 6k rpm. Possibly the lower oil level meant the bottom end was starved of oil like you said.
So any recommended builders? as per the previous post? and where to source parts for the build
Midland Engine Centre will do the build if you ask them. And that package you said sounds decent. But I would consider looking at Spool Imports website. They come with rods, pistons, bearings and head gasket for around $2500. All forged, ARP rod bolts and you can choose comp. Probably the cheapest option as second hand RB26's are still pretty expensive - this way also you will have a brand new engine, so you know condiiton and can expect a good life from the motor.
If you're not comfortable with the engine transplant, contact Mike Don @ RT Conversions. No one would have heard of them, they do very specialised stuff. In fact, its my old man :) We built my RB30/25 which runs in a 1973 Holden HQ (initially was running an RB30e back in 05) and has also dropped a TT-1UZFE in his 2 Door GTS. Is also building a 67 Mustang fastback with 08 Mustang running gear. Him and my uncle Nino (proprieter) can do it all and I guarantee it will cost you half what any workshop will quote.
Otherwise, take it to a workshop you can trust i.e All-star or Ovaboost. That way if problems do occur you can take it back to them any time and get them to fix it.
Edited by cactus
I didn't insist on anything, I've seen cars put straight on a dyno after an oil change and straight to a track after an oil change. I drove it as I would any other day and waited 15 minutes as it idled and drove 5 minutes slowly drive below 2k rpm to warm it up before I gave it some.
Why do most people insist on trashing the car just after oil change??
what do they hope it will achieve??
its beyond me?
Your driving isn't the issue... a GTR warmed up properly and then driven WOT to 6K should love you for it :) To starve the bottom end you would have to be doing serious launches or hard cornering, anything to get the oil moving away from the pickup in the pan... sustained high rpm will pump a lot of oil into the head too but it doesn't sound like you were doing that
The bearings may have already been damaged and the previous owner has chucked some super thick oil in it to mask the noise... its a possibility but I've had bottom end knocks in a few of my engines and they were all pretty god damned loud... loud enough to be heard in the car with a helmet on so I would be surprised to learn thicker oil could mask the sound
Good luck with it
Sounds like young mechanic drained oil, proberly started it without oil and then realized he had no oil in it and then put some in.
Was it knocking when you picked it up?
What oil pressure do you have? Normal???
I just finished reading all of this and i thought i'll add something.
About two and half years ago my brother asked me to service his N14 SSS.
I had dropped the oil and removed his oil filter, he came walking pass and i asked my bro if he could move the car back for me so i can get the oil pan out from under the car.
He not realizing that the car had no oil in it and thinking ahh ok i'll start the car and move it back for me.
He started the car and i yelled out to him switch the car off quickly. Car probley was running for about 5 or more secs. before he switched it off.
Me thinking oh shit he has just killed his car.
Well i can tell you that this car is still going great after all these years.
It might not of been a gtr however give the fact the car ran without oil for only a really short bit of time was either pure luck or maybe did not do any damage as the engine was still cold.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
