it was the first time for me changing the oil since i've owned the car, when taking the old filter out the oil seemed thicker than the HPR-10. So maybe there was an underlying issue with the engine possibly being hidden by the thicker oil?..
The car was warmed for 15 minutes to let the new oil circulate after the oil change, then driven with some spirit with spurts to 6k rpm. Possibly the lower oil level meant the bottom end was starved of oil like you said.
So any recommended builders? as per the previous post? and where to source parts for the build
Midland Engine Centre will do the build if you ask them. And that package you said sounds decent. But I would consider looking at Spool Imports website. They come with rods, pistons, bearings and head gasket for around $2500. All forged, ARP rod bolts and you can choose comp. Probably the cheapest option as second hand RB26's are still pretty expensive - this way also you will have a brand new engine, so you know condiiton and can expect a good life from the motor.
If you're not comfortable with the engine transplant, contact Mike Don @ RT Conversions. No one would have heard of them, they do very specialised stuff. In fact, its my old man :) We built my RB30/25 which runs in a 1973 Holden HQ (initially was running an RB30e back in 05) and has also dropped a TT-1UZFE in his 2 Door GTS. Is also building a 67 Mustang fastback with 08 Mustang running gear. Him and my uncle Nino (proprieter) can do it all and I guarantee it will cost you half what any workshop will quote.
Otherwise, take it to a workshop you can trust i.e All-star or Ovaboost. That way if problems do occur you can take it back to them any time and get them to fix it.
Edited by cactus
I didn't insist on anything, I've seen cars put straight on a dyno after an oil change and straight to a track after an oil change. I drove it as I would any other day and waited 15 minutes as it idled and drove 5 minutes slowly drive below 2k rpm to warm it up before I gave it some.
Why do most people insist on trashing the car just after oil change??
what do they hope it will achieve??
its beyond me?
Your driving isn't the issue... a GTR warmed up properly and then driven WOT to 6K should love you for it :) To starve the bottom end you would have to be doing serious launches or hard cornering, anything to get the oil moving away from the pickup in the pan... sustained high rpm will pump a lot of oil into the head too but it doesn't sound like you were doing that
The bearings may have already been damaged and the previous owner has chucked some super thick oil in it to mask the noise... its a possibility but I've had bottom end knocks in a few of my engines and they were all pretty god damned loud... loud enough to be heard in the car with a helmet on so I would be surprised to learn thicker oil could mask the sound
Good luck with it
Sounds like young mechanic drained oil, proberly started it without oil and then realized he had no oil in it and then put some in.
Was it knocking when you picked it up?
What oil pressure do you have? Normal???
I just finished reading all of this and i thought i'll add something.
About two and half years ago my brother asked me to service his N14 SSS.
I had dropped the oil and removed his oil filter, he came walking pass and i asked my bro if he could move the car back for me so i can get the oil pan out from under the car.
He not realizing that the car had no oil in it and thinking ahh ok i'll start the car and move it back for me.
He started the car and i yelled out to him switch the car off quickly. Car probley was running for about 5 or more secs. before he switched it off.
Me thinking oh shit he has just killed his car.
Well i can tell you that this car is still going great after all these years.
It might not of been a gtr however give the fact the car ran without oil for only a really short bit of time was either pure luck or maybe did not do any damage as the engine was still cold.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
