  Cerbera said:
much hate bort!!!
i just remember it running a fairly low mph last time it went down to the plex, figured something must have been fixed to get power back up there
Marbles only change made from when it ran at WAW was from the bridgestone r comps to R888 toyos and power still the same :)
  • Replies 40
It's simply impossible to run 10 second pass form a R32 GT-R in stock form Char, even with some boost ramped through the turbos. Unfortunately there is dreamers around the place who make those sort of claims and can through our peoples perceptions on what stock car's can do.
Top work with the pass, be keen for further 60ft and mph details.
  GTS-t VSPEC said:
Bart, Say congrats to Will, I'm more impressed with the 55sec at Wanners though, and I know that was only the first few test laps, so sure it has more in it :P
Yea PC the 55 was good considering it had miss n yet to get on the brake hard .. We be there for the next No Limits in december to try again :happy:
  Char said:
cool story bro? wasnt it u who asked if it was mph. also, dont call me an idiot.
all i know is he claimed to know sam ie slyder and he owns a silver r32 gtr..
i know the guy. its a white 32 gtr and it ran 11.2 or somthing with 1.5bar boost (he thought it said 15psi).
back on topic, i like the rims :P
Yes, I asked what mph it ran because that give you more of a indication about the cars true power and I was interested...
You on the other hand wouldn't think of that because you have no idea, go back to school :P
  Char said:
nice one, and nothing wrong with white rims.
when i was at kwinana last, a bloke ran high 10 with his stock 32 gtr with just boost controller, God knows how much boost he was running though he kept winding it up more and more. i wonder if his engine made the trip home
only chance of that happening is if he bought a !@#$%^&* GTR and he doesnt know what the previous owner(s) put into it
otherwise 2 your both on crack :P
no need to be a f**kstick ^
from what I have read with intended boost the GTR was ment to run from factory is around 12.90 down the quarter
"The electronic boost control had a small physical restriction in the control lines. It was marked in yellow so the new owner could remove it and enjoy a safe factory boost increase.[15] After this increase the car would put out ~230 kW and could do 0-100 km/h in 4.7seconds and quarter mile in 12.8 seconds. "Wikepedia" "
Edited by BANGN
  Tony de Wonderful said:
With NOS?
Highly unlikely, most street nitrous kits will see you gain about 30-70rwhp so possibly high 300's hp. Anything beyond that sort of boost and gas will see stock parts breaking and flying heads flying into the sky. I drove a bog stock GT-R with pods and a exhaust to 12.97@107mph, pretty spot on and considering the age they work well. To run a 10 in a GT-R you need around 128+ mph and beyond 550rwhp, working off figures in WA in the past with a good starting 60ft.
Edited by monga
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
